OEM Alarm Issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by seilermj, Jul 2, 2017.
  1. Jul 2, 2017 at 8:54 AM
    seilermj
    seilermj [OP] New Member
    2003 Tacoma Crew Cab TRD
    Hey all,
    I'm having a couple issues with factory car alarm on my 2003 Tacoma Crew Cab. Almost 2 years ago my car alarm went off in the middle of the night for absolutely no reason. Only way I could get it to stop was to disconnect the battery. Luckily, it hasn't happened since. Now, I'm having a new issue. Every time I open/close the door, I heard 2 "thunk" noises like my door locks are actuating twice. I've watched the locks and they aren't moving, it just sounds like they are. An inconvenience, I know, but still annoying. In addition to this, now, at random times, my alarm will go off when I open the unlocked door with the alarm unarmed. For this one, I can get the alarm to shut off by simply starting the truck. The door lock sounds and alarm going off when opening the unlocked door (with the alarm unarmed) seem to be related because they both started happening at the same time. Does anyone know how to fix either of these issues? Please help. Thanks!
  2. Jul 3, 2017 at 1:48 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    SO, if the alarm is truly oem, it was dealer installed, and can be reversed. Sounds like the module may be faulty, however I am not to up on the rs3200 alarm. Hopefully that atleast gets you a starting point?
    @mechanicjon I think has had to deal with them on occasion?
  3. Jul 3, 2017 at 9:40 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Are you sure it's the factory installed RS3200 alarm system? If so sounds like your module went bad. Maybe a grounding issue or something like that. You'd be surprised how weird electrical circuits start acting without a good ground.
  4. Jul 4, 2017 at 7:45 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I have zero experience with the dealer/factory alarms. FSM doesn't have a wiring diagram. I know the keyless entry system a little but not the alarm. Check for grounds and the drivers door latch key switch.
