OEM All Weather Flooring Part Numbers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BassAckwards, Jul 29, 2016.
  1. Oct 12, 2019 at 3:29 AM
    #121
    Blain
    Blain I ain't got time to bleed
    Tx
    What floor mats are y'all using? I've had gray Weathertechs for over 12 years. Weathertech doesn't recommend the exact fits on vinyl floors, plus I'd want black anyways.
  2. Oct 12, 2019 at 5:24 AM
    #122
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    I don’t use them, just let the flooring contain all dirt and liquids.
  3. Oct 12, 2019 at 5:37 AM
    #123
    Reinhardtius
    Reinhardtius Well-Known Member
    07 Base 2.7L 5SP
    Any ideas for folks with a Regular Cab?
    BassAckwards[OP] likes this.
  4. Oct 12, 2019 at 9:26 AM
    #124
    BassAckwards
    BassAckwards [OP] Well-Known Member
    2009 Tacoma AWD Turbo 2TR-FE
    Im running the OEM rubber ones that came with my truck
    Blain[QUOTED] likes this.
  5. Oct 14, 2019 at 2:39 PM
    #125
    BassAckwards
    Cut it down to size would be my suggestion
  6. Oct 15, 2019 at 10:28 AM
    #126
    Blain
    Tx
    Floor was just delivered. The reason I was asking about the 2006 access cab is there is nothing in the first few years of access cabs with regards to a center storage or speaker between the rear seats. So with this vinyl floor, I now have to cover up some holes and gaps for something between the seats. I have some sound deadening on order, so once that comes in I'll attempt the install. But I'm not to happy right now.
  7. Oct 16, 2019 at 9:03 AM
    #127
    SargeBSA
    SargeBSA With self-discipline most anything is possible.
    Cascade Mountains
    2021 SR5 Tundra 4x4
    TRD Offroad Wheels 265/75 18 General Grabber ATX's,
    Post pics I'm curious.....
  8. Oct 16, 2019 at 1:02 PM
    #128
    jon_elc
    jon_elc Well-Known Member
    NorCal
    2011 SR5 4x4 Timberland Mica Snugtop Rebel
    245-70R-17 Revo3 Cut mudflaps 4.5" F / 1.5" R
    i need this
  9. Oct 17, 2019 at 6:19 AM
    #129
    Blain
    Tx
    It's going to be a bit. I'm waiting on my CCF order from Foam Factory to do some sound deadening on the floor while I have everything out. But I'm going to have to spend even more $$ on getting some kind of patch made. Damn half assed money pit and I haven't even started!
  10. Oct 17, 2019 at 4:21 PM
    #130
    jon_elc
    NorCal
    My truck came with 4runner husky liners which basically fit ok in the front, but are cut to fit around the seat tracks in the back. i'm partially worried that i'll get some melted snow leakage past the cuts into the carpet and make it soggy /musty... but i'm trying to get waterproof seatcovers first and then decide on floor covering after, since i cous easily make a big ol mess on these really clean seats! (my current car has black vinyl seats , easy cleanup! and the carpet is black, so coffee spills are hidden) this truck has a grey interior!!!!!
  11. Oct 18, 2019 at 2:13 PM
    #131
    Sandwich
    Sandwich New Member
    2010 AC V6 4x4 MT
    Has anyone had any luck getting these in Canada?
  12. Oct 19, 2019 at 5:37 AM
    #132
    Blain
    Tx
    I'm probably going to put mine up for sale, sucks because I already threw away the box. I would need to cover about 8 holes that are already cut out and then recut 2 other areas for tie down points. And until I remove everything out of the truck, I won't be able to tell exactly how little coverage I will have around the rear seats. What an expensive disaster.
  13. Oct 20, 2019 at 4:26 AM
    #133
    SargeBSA
    Cascade Mountains
    2021 SR5 Tundra 4x4
    Welcome to TW where nobody is satisfied and everything is an expensive disaster.
    :sawzall::welder: Still waiting for photos of what you are referencing in regards to holes.
  14. Oct 20, 2019 at 4:30 AM
    #134
    Blain
    Tx
    Did you read my response above? keep waiting.
  15. Oct 20, 2019 at 4:38 AM
    #135
    Blain
    Tx
    The flooring from the middle of the tunnel behind the front seats, right before the three holes cut for the console, to the rear of the cab is wrong. 1/4 of the entire floor, around the rear storage areas, would need to be hand fab'd with a like material to have any kind of coverage. A 2006 only has a tie down for child seats on the passenger side. This floor is missing huge sections of floor for tie downs on both drivers and passenger sides, that I don't have and need to be made and replaced.
  16. Oct 20, 2019 at 5:08 AM
    #136
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    @Blain the hole(s) not matching sucks...
    :annoyed:
    Could you cut your existing rear carpet somewhere under your front seat and have all weather flooring in the front and your OEM carpet in the rear?
  17. Oct 20, 2019 at 8:13 AM
    #137
    Blain
    Tx
    My carpet is the light grey, so no cutting for me.
    I'm trying to make it work and was looking for a similar textured and thickness vinyl to use to patch all the areas where it's missing. I guess to add insult to injury I found this site. You can order replacement carpet or vinyl flooring and Tacomas are listed. A complete floor for a 2006 Tacoma access cab in black vinyl is $262.
    https://www.accmats.com/commerce/2006/Toyota/Tacoma/Flooring/17589/
    Norton likes this.
  18. Oct 20, 2019 at 8:29 AM
    #138
    Blain
    Tx
    Now that I'm searching for the vinyl, I'm seeing it for half price $131. It says the backing is (loose) and it's full coverage, so you'd have to trim it.
  19. Oct 23, 2019 at 6:00 PM
    #139
    Blain
    Tx
    Whew, full day. I ended up installing sound deadener since I was pulling everything out of the cab. I have a sheet of vinyl flooring being delivered Friday. I'm going to use it to try to repair all of the areas behind the seats, it's a mess. If I had to do it over again, I'd buy a full replacement vinyl floor in gray, for $135 and cut out all the holes specific to my truck.
  20. Oct 23, 2019 at 6:01 PM
    #140
    Blain
    Tx
    You can see the foam under the vinyl. I still have to place the MLV in this area, then I'll reinstall the seatbelts and seats.
