OEM Antenna Adapter for SiriusXM Radio
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tarvis, Dec 11, 2019.
  1. Dec 11, 2019 at 12:48 PM
    Tarvis
    Tarvis [OP] Well-Known Member
    Travis
    Bel Air, Maryland
    2018 Metallic Gray SR5 Double Cab
    To be fair it is BEHIND it and to the left or right! :thumbsup: I also said to the SIDE WALL of the dash :D:D
  2. Dec 11, 2019 at 12:48 PM
    caribe makaira
    Caribbean, Puerto Rico
    If the wires are long enough to reach the sides then return to center, you'd be fine also...
  3. Dec 11, 2019 at 12:51 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Stick it in vicinity of the glovebox if you can. If you get an issue with the adapter or stock antenna you won’t have to pull the stereo back out to swap it out/fix it.
    edit; I had one of the Sirius pucks crap out on me and it was easy to troubleshoot since I just pulled the glovebox and had access
  4. Dec 11, 2019 at 12:53 PM
    Tarvis
    Travis
    Bel Air, Maryland
    That is very smart. Will give it a shot, thanks.
  5. Dec 11, 2019 at 2:09 PM
    DirtyGovnuh
    DirtyGovnuh Well-Known Member
    2021 TRD OR DCSB 4x4
  6. Dec 11, 2019 at 5:21 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    ahh..i thought it had a separate box under the head unit. so this brings me to the question i live in hawaii, no xm here, so if i move my truck to the mainland how would i activate that internal xm/ sorry to kind of hijack thread.
  7. Dec 11, 2019 at 6:45 PM
    Tarvis
    Travis
    Bel Air, Maryland
    NO problem. My question is already resolved. It is activated by default. You should just be able to change the source when you have XM signal. Assuming your oem head unit has SiriusXM
  8. Dec 11, 2019 at 6:48 PM
    Tarvis
    Travis
    Bel Air, Maryland
  9. Dec 12, 2019 at 7:56 AM
    Tarvis
    Travis
    Bel Air, Maryland
    I was thinking about this and remembered something this morning... The XM Module is mounted to the bottom of the stock entune head unit. I recall it coming apart into two pieces when I sold my OEM head unit. It wouldn't have worked with an aftermarket head unit though because all of the controls would be lost. Nothing linking the old XM module to the aftermarket head unit.
    kahanabob[QUOTED] likes this.
  10. Mar 10, 2024 at 2:00 PM
    eight
    eight Well-Known Member
    2019 silver Tacoma TRD sport
    I know I’m a few years off, but did that adapter work? I’m trying to install an Xm module
    auskip07 likes this.
