OEM Audio Plus vs Trailgridpro Plug & Play
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bgrath08, Sep 25, 2024.
  1. Sep 25, 2024 at 4:15 PM
    bgrath08
    bgrath08 [OP] Member
    Brandon
    South Carolina
    2017 Quicksand DCSB OR 4x4 Auto
    I have a 2017 TRD Off Road with the non JBL sound system. I have been considering buying the OEM Audio Plus Reference kit with single subwoofer, but came across the Trail Grid Pro plug and play Alpine system. I was wondering if anyone has had experience with both? Do you think the OEM Audio Plus is worth the extra money? I have seen that people say that it is a well balanced system and easy to install, but I like that the Trail Grid Pro system is significantly less expensive. Here is a link to both:
    https://oemaudioplus.com/product/toyota-tacoma-dbl-cab-16-base/
    https://trailgridpro.com/products/a...hannel-amp-powered-subwoofer-kit-16-23-tacoma
    I like the plug and play aspect of both since I have never installed an audio system before, but I have soldered and worked with wiring before. I would be open to building a simple system myself if people think that it would be the better route to go versus the both the Trail Grid and OEM Audio Plus
  2. Sep 26, 2024 at 6:56 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    The trail grid pro system will give more volume and a bump in bass
    The OEM system will give you both but more overall balance of sound . But here’s the thing you can build a nice system for the OEM price . Crutchfield can set you up with lots of good stuff ., and if your afraid if certain wiring they can do a head unit that’s plug and play. For an extra charge .
    Change out your speakers ( same work ) buy a 5 channel amp and a sub to go in your rear passenger bin and your good to go
    I suggest separates up front ( dash speaker and door speaker ) , door speaker s rear doors
    I think Skar makes a box for our truck now , pick a nice 10 inch woofer
  3. Sep 26, 2024 at 6:57 PM
    BlueRibbonRM
    BlueRibbonRM Well-Known Member
    2023 TRD OR
    I haven't seen this before, don't see anything in the audio section about it, so I am curious now too. I was pretty set on budgeting for the OEM audio one but this looks like a potentially good contender for simplicity if it sounds decent.
  4. Sep 26, 2024 at 7:15 PM
    Tony382
    Tony382 Well-Known Member
    2022 Tacoma TRD Sport
    I can't say on the TrailGrid Pro, but I have the OEM Audio Plus system with the single sub. I'm no audiophile but I find the sound is very clear and it bumps pretty good. I have the Bass level set to a little bit past halway and the rear view mirror will twerk like Cardi B
  5. Sep 27, 2024 at 7:13 AM
    bgrath08
    Brandon
    South Carolina
    Thanks for the advice. I will do some research and decide.
    It just seems like there are pros and cons to all three. People seem to love the OEM Audio and I like that it is designed for the truck and I don't have to worry about tuning anything. I like that the TrailGrid Alpine system is cheaper and frees up money to add in a new head unit as well. I do think building my own system would be fun, but I need to research and learn more.
  6. Sep 27, 2024 at 12:38 PM
    TruckGuy63
    Gilbert
    New York
    I did a Avic 8600 Nex Pioneer
    4 channel audio control micro amp
    Audio control mono micro amp
    10 inch sub JL in a box behind rear passenger seat
    Coax speakers in rear doors Alpine
    Separates up front alpine
    All from crutchfield
    Super clean sound and really nice . It makes me want to drive the car just because of the system lol
    PirieDog likes this.
  7. Oct 13, 2024 at 10:07 PM
    PirieDog
    PirieDog Member
    Spencer
    2020 Black Tacoma TRD Sport
    Completely stock as of now
    How much did all of that cost you? And how would the sound quality of your custom made system stack up against the OEM or Trail Grid Pro kits?
  8. Oct 13, 2024 at 10:38 PM
    RDT415
    RDT415 DUCTACO
    Sonoma County
    23 TRD Pro 6MT / past 04 DCSB 4WD
    I’ve got the complete OEM Audio plus system with the 8” sub. The 6MT pro’s do not come with the JBL system. Decided on this kit as I wanted a balanced system that was a seamless install and retained the factory head unit. Did the install myself in a day including sound deadening in the doors and back wall of the cab. Upgrading the sound system certainly be done with other components, lots of info on TW. The “all in one box” plug and play made it an easy decision for me. As far as how it sounds, I dig it - No regrets at all. Enough bass, the mids and highs are awesome. Great soundstage as well. Whichever way you go I’d sound deaden the doors / back of cab.
  9. Oct 14, 2024 at 3:15 AM
    TruckGuy63
    Gilbert
    New York
    Head unit 800 ish
    Jl sub ( if you go that route expensive ) 900 there are other ways and still good bass for much less
    Amps about 600
    Speakers 400ish and then cables and maestro
    It adds up for sure. I will say you can put together a system that’s good for less with some thought .
    A good head unit is important
    Sub / you could go with a Rockford sub in a box that will fit
    Amps you could do a 5 channel kicker or alpine ,and save some there
    Speakers there are tons around
  10. Feb 19, 2025 at 2:27 PM
    AmosIII
    AmosIII Well-Known Member
    2022 TRD OR DCSB MT Army Green
    OME MT64 Suspension
    OP did you pull the trigger on one of these? I am seriously considering the Focal speaker bundle from Trail Grid and either the Alpine 4 channel amp and powered sub kit from them or just getting a nicer amp from crutchfield with the plan to add a nicer sub / sub box in the future. If you went with the trail grid setup very interested to hear your opinion on the sound quality from that amp and sub. Thanks
