OEM Ball Joints Durability
Discussion in '1st Gen. Tacomas (1995-2004)' started by ryanbelfor, Jan 16, 2019.
  1. Jan 16, 2019 at 11:44 AM
    ryanbelfor
    ryanbelfor [OP] Member
    1996 Tacoma Base Regular Cab 4x4 Manual
    None, yet...
    Ive heard from everyone that OEM is the way to go for pretty much everything, especially ball joints. After having issues with proforged boots offroad i want some advice on what ball joints to get for someone like me who normaly drives on roads but occasionaly hits the trails a couple times a month. will OEM hold up to rocks, water, mud, etc?
  2. Jan 16, 2019 at 11:45 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Yes. They should be replaced every 100k. It also doesn't hurt to check them periodically for play.
  3. Jan 17, 2019 at 1:32 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  4. Jan 17, 2019 at 3:47 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    OEM ball joints are very durable (I had 300k+ miles / 22 years on factory LBJ and still were solid) as long as boot it is not broken, so original grease is there and not contaminated. As soon as grease gets contaminated or washed out (because of cracked boot for example) OEM or aftermarket, any ball joint will be gone in a mater of days (or weeks if you are lucky).
    So if you go off road and suspect the ball joins might get abused (driving on rocks, bushes, mud or water) just check if all boots are in like new condition (no cracks or torn, no grease leaking out). And of course follow the maintenance schedule which calls for inspecting all ball joints every oil change.
    OneWheelPeel likes this.
  5. Jan 17, 2019 at 9:29 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  6. Jan 17, 2019 at 12:44 PM
    KSDoubleTaco
    KSDoubleTaco Well-Known Member
    Kansas
    02 DoubleCab
    Go OEM on the ball joints. I went cheap on a set and nearly wrecked the truck with my kids in it. Fortunately it failed during a very low speed turn and didn’t do any body damage.
    OEM cost doesn’t seem so bad after you replace a CV axle, upper ball joints, brake lines, etc. as a result of the cheap lower ball joint failure.
    As a side note, I went with Camburg UCAs with the 1” uniball instead of upper ball joints. They’re stronger and allow a lot more downward travel, particularly if you’re lifted.
