OEM battery life in cold weather
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NoSilverBullet, Jan 10, 2015.
  1. Jan 12, 2015 at 1:06 PM
    NoSilverBullet
    NoSilverBullet [OP] N60 member
    Northern Canada
    2012 AC 2.7 MT 4wd
    Old Man Emu suspension: 884x coils, Dakar leaf pack, Nitrocharger Sport shocks. Cruisin Offroad bolt-on sliders. Relentless Fabrication aluminum front and mid skid plates + steel transfer case skid. SnugTop Hi-Liner "Sportsman" canopy. Hella Rallye 4000i Xenon (flood beam).
    I use 0W-20 Mobil One.
  2. Jan 12, 2015 at 1:16 PM
    NoSilverBullet
    Northern Canada
    2012 AC 2.7 MT 4wd
    The weekend after I changed my battery, we had even colder weather. I tested a cold start after being parked for about 18 hours in below -30C/-22F weather.
    The truck started right up! Although it sounded pretty rough.
    I have a battery pad and block heater that I try to use when it's that cold, but it's not always possible.
    Also, thanks to all for the feedback so far!
    As some have pointed out, it's not really possible to predict battery life since the usage varies so much from one truck to another. In my case, the battery was really still doing well in warmer weather. It just couldn't provide the required power in really cold weather I guess.
  3. Jan 12, 2015 at 1:34 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Just replaced my factory 08' last month, still was working, but started to sound weak on cooler mornings. No really cold weather here though. As others have stated, heat (and heavy drains) is what kills batteries, cold is what makes the damage show up.
  4. Jan 13, 2015 at 4:10 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Heat actually speeds up the electrochemical reaction in a healthy battery and cold slows it down. As a battery ages, the active surface area on the plates is reduced or the grids corrode; thus, resulting in decreased CCA performance and amp hour capacity. Starting batteries are optimized with a lot of surface area using thinner plates to produce very high current for very short periods of time. Deep discharges, high underhood temperatures, undercharging, undersizing, or excessive vibration can significantly shorten the life of a starting battery.
  5. Jan 14, 2015 at 10:13 PM
    NoSilverBullet
    Northern Canada
    2012 AC 2.7 MT 4wd
    This is very well explained. Thanks!
  6. Jan 14, 2015 at 11:37 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    5 Years on my OEM.
    Bush roads, -40 *c a few times
    9500 lb winch use
    Sounds not too happy in VERY cold weather, but always starts. I am pleasantly surprised.
  7. Jan 14, 2015 at 11:44 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    mine lasted 4.5 years.... replaced with a diehard gold....
  8. Jan 15, 2015 at 5:22 AM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    this summer will be 3 yrs. have had some -25F (ambient) winters. still on oem battery with no issues.
    it is garaged during the night, but sits outside during the day from 7am to 5pm. do not have a block heater installed.
  9. Jan 15, 2015 at 9:49 AM
    81shark
    81shark Well-Known Member
    still running the factory battery on my '06. in service data of 11/05. so 9 plus years.
    ran it pretty much flat once in 2012...after sitting for a few hours it had just enough to start.
    i've had an amp hooked up to it since 08ish.
    it's defiantly getting close, but i am seem to say that every winter.
    haven't done any maintenance on it.
  10. Jan 16, 2015 at 5:03 AM
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    The average expected battery life for Montana based on the Interstate study is between 56 and 61 months, so 108 is very good. If the OEM was a Panosonic from Japan, it has thicker plates. If properly maintained, 10 to 12 years of life is not all that uncommon for them in the extreme cold weather areas. IMHO, keeping it fully charged, removing the terminal corrosion, minimizing vibration, or adding distilled water (if required) is about all that is required for a longer service life for any starting battery.
  11. Jan 16, 2015 at 5:48 AM
    zonian
    zonian Well-Known Member
    Paul
    Knee Deep in the Hoopla.
    2012 TRD Sport 4X4 - Pyrite Mica
    Raptor 4" Black Oval Nerf Bars, Hard-Wired Uniden RD9XL Radar Detector, Anytime Fog Light Mod, 12V Power outlet in Bed, Tailgate Anti-theft Mod, Distinct Offroad lightbar, 2 Hella Micro FF Driving Lights, 2 Hella Micro FF Fog Lights, Rear Slider Window Opener
    Just replaced my OEM battery last week. 2.5 years old...totally dead on one of those below 0 mornings...wouldn't even click. I'm just over 73K miles, mostly highway. I was surprised that it didn't last longer.
    Paul
  12. Jan 17, 2015 at 8:09 AM
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Paul, I am surprised as well. The four most common premature battery failures are:
    1. Low Electrolyte.
    2. Sulfation caused by undercharging due to driving habits, terminal corrosion or improper charging.
    3. Deep Discharges/Freezing.
    4. Excessive Parasitic Load.
    Manufacturing defects are typically less than 1%.
