OEM Battery Life
Discussion in 'Technical Chat' started by Elkhound, Apr 3, 2013.
7 Year Old OEM Battery Replacement
Poll closed May 3, 2013.
  1. Replace now as a precaution.
    41.2%
  2. Run it until it dies.
    58.8%
  1. Apr 22, 2013 at 4:28 PM
    Large
    Large Red
    From what I've read, & personal experience they tend to crap out at about 70k
  2. Apr 28, 2013 at 1:56 PM
    slodc4
    slodc4 Conceal Carry
    Steven
    Winterville, NC
    Locked 17 trd sport
    Mine died at 5 years and 110k miles
  3. Apr 28, 2013 at 8:21 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Mine's going strong at 7.5 years and 65k.
  4. Apr 28, 2013 at 8:35 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    So is it best to go by mileage or years with battery life? The reason i ask is mines 6 years old (bought new in April of 07) but the truck only has 20,000 miles.
  5. Apr 28, 2013 at 8:38 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Age and temperature.
    Lower miles is going to be a negative because the battery will be spending more of it's life in a lower state of charge.
    6 years in the high desert? I'd replace it before summer.... and I plan to do the same on my '08 unless I can find documentation or a sticker somewhere indicating that it is not original.
  6. Apr 28, 2013 at 8:40 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I replaced my 3 year old oem battery as a precaution.... Last thing I need is to be stuck somewhere at an inoportune time with kids
  7. Apr 29, 2013 at 6:31 AM
    wyotaco06
    wyotaco06 Well-Known Member
    Offroad 4x4 06
    Replaced the stock battery when it was 7 years old with an interstate megatron.
    It started the truck up just fine, but replaced it as a precaution to avoid a bad situation.
    A good thing about replacing a battery before its totally dead is it gives you time to shop around and find a good deal on a new one. Got the Interstate 27F battery for $89 after looking for a few weeks.
  8. Apr 30, 2013 at 6:11 AM
    rleete
    rleete Grumpy old man - get off my lawn
    Roger
    Rochester, NY
    Base DC, SR5, TRD Sport
    Billet grill
    If you get your batteries from Interstate (and why wouldn't you?), ask if they have any blems. Much cheaper, you just don't get as good a warranty. Only one year.
    Regular battery: $112 + tax.
    Blem: $40, tax included.
  9. May 5, 2013 at 5:49 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    that is what my 2009 did a few days before it died prematurely. It was only 3 years old. I had a Ford battery crap out the first year. Fortunately I had the boat with me and just pulled one out of it.
  10. May 6, 2013 at 7:01 AM
    randyg123
    randyg123 Well-Known Member
    Randy
    2024 Bronze LTD
    This just dawned on me on what we used to do back in 'the day'. I am rarely off road or in remote locations anymore so having a battery die isn't that much of a deal. Get a jump, go get a new battery, not that big of a deal. But way back in the olden days when I had tons of room under the hood of my 74 F-100, I installed a second battery with a knife switch. Other Ford and Chevy drivers did the same. This was mostly so we can run steroes for hours and hours and hours while camping but the security measure was there too. Had a small tool box bolted in under the hood too. Aaaaah, those were the days:)
  11. May 6, 2013 at 10:21 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    7 years and 150,000 miles on my original OEM battery. I've drained it below the point of starting at least 4 or 5 times now, and at least 3 of those times even the dome light wouldn't come on.
    Each time I've put it on an automatic charger for a few hours, or jumped it and drove 30-45 minutes to work and put it on the charger when I got home. I credit the charger with maintaining it this long. It has a "desulfinate" cycle, and switches over to trickle charge once it's fully charged.
  12. May 6, 2013 at 10:24 AM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    6 years... Still on my 3rd one for the last 16 years....
  13. May 6, 2013 at 6:07 PM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Elkhound, run it until it (almost) dies.
    I have always had some indication that the battery is starting to go.
    For example, draining by leaving the dome light on, a little slower to start, etc.
    The main thing is to listen to your truck. It will tell you what you need to do.
    When that happens I do a trickle charge, and always seem to get another year or two.
    After a few "issues", but not to the point of getting or going to get stuck, I replace with a high quality battery. Your time will come. Probably in the fall, and just in time for your harsh New England winter. Good Luck.
  14. May 7, 2013 at 6:45 AM
    piercedtiger
    Jon
    Southern Tier, NY
    That's what I do. Throw it on the charger all day or over night if I leave the heated mirrors or anything else on that causes a struggle to start or no indicator lights. I've done that 4-5 times now, and still have the same battery the truck came with in 2006.
  15. Oct 10, 2013 at 8:19 PM
    #35
    NiceGuyEddie
    NiceGuyEddie Well-Known Member
    Chino, SoCal
    none yet
    3 years, 10 months, and 64,000 miles.
    very surprised.
    near a park reading a book, i charged my phone and listened to Pandora thru the AUX for 1 hour a few days ago. the next day, it took 3 turns/cranks to start. first rain of the season, first cold of the season, so i just said, "that was weird."
    next day, 5 turns/cranks to start. drove to Autozone. they checked it and said it's bad. it would not start again - not even close, and i had to buy a battery at the store.
    very surprised.
    :cool:
  16. Oct 11, 2013 at 12:29 AM
    #36
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I'd say very lucky 2 B at Auozone and not in a park when it would not start again - couldn't have worked out better. :D
  17. Oct 11, 2013 at 11:39 AM
    #37
    Rich91710
    Rich
    Los Angeles
    08 Base
    VERY lucky that he had a warning.
    Any time I've lost a battery, it's been in the middle of the day, no warning, just get back in after making a stop to buy something and nothing.
    Happened once at Pep Boys, and happened once about a block away from Walmart.
  18. Oct 11, 2013 at 12:05 PM
    #38
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    09, 22K miles...last week it was starting to be hard to start and
    the starter relay would chatter upon an attempt to start.
    Took it to the parts place, they checked the battery and it would
    only deliver about 400cca....
    My OEM battery had the GRN/YEL/RED indicators...was still showing
    GRN....so as somebody on here said and even Toyo service,
    don't trust the indicators.
    Put in a new battery, all good now. Snappy starts like it used
    to be. Relatively cheap insurance, why chance it?
    PC
  19. Oct 11, 2013 at 12:18 PM
    #39
    Rich91710
    Rich
    Los Angeles
    08 Base
    400cca is plenty. Rule of thumb back in the day was one cca per cubic inch.
    They are correct on the indicator. It is a hydrometer, but it is only showing the status of one of the six cells in the battery. It is a decent indicator of the overall state of charge on a healthy battery, but it can't tell you if you have one or more sulfated or shorted cells.
  20. Oct 11, 2013 at 1:10 PM
    #40
    george3
    New Jersey
    Sounds like U were lucky 2. I've got a 08 so 5years old. Haven't had any problems but after reading about batteries just crapping out with no warning I am thinking of replacing the battery just so I don't get caught.
