OEM Bed Extender Install Write-Up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by adrenaline66, Apr 25, 2011.
  1. May 17, 2018 at 9:39 PM
    #101
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Anyone have a pic of how the black strap is rigged into the steel pin thing that latches into the tailgate?
    I bought my extender used and I think the straps might not be set up correctly.
    This is a pic I grabbed of the www. It looks like the strap is somehow rigged through the bottom portion as well as the top. I'm assuming there's a reason this "buckle" was designed as it is.
  2. Jun 3, 2018 at 2:16 PM
    #102
    IA Mike
    IA Mike Well-Known Member
    Iowa
    2022 Tacoma Limited MGM
    Custom lightened wallet and shiny new payment booklet
    Happened to be out at the truck today and took a couple pics. "Buckle" is a standard 'over, under, over' strap routing. The offset is to allow clearance for the pin to lock into the tailgate latches. Hope this helps.018 (1024x768).jpg 020 (1024x768).jpg
    NMTrailRider likes this.
  3. Jun 3, 2018 at 3:43 PM
    #103
    NMTrailRider
    New Mexico
    Thanks much! Mine look like yours so it looks like they're done correctly.
  4. Jun 14, 2018 at 5:02 PM
    #104
    CampTruck
    CampTruck Thats. What. She. Said.
    Brooks
    NC
    2018 Silver TRD Sport DCSB 4x4
    Bartact covers, Hondo knobs, OEM bed cover, Subie Tweeters, interior chrome delete, a/c hose extension/relocate, blacked lower bumper, OEM bed extender and mat, Stealth running boards, debadged
    I dont like the idea of installing with just bolts or screws so picked up some m5 Button head screws washers and nuts
  5. Jul 5, 2018 at 5:52 PM
    #105
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    I bought a bed extender that didn't come with instructions/template. Is the center/bottom bolt of the bracket 7 1/8" up from the bed "floor," and 1 1/2" towards the cab from the back edge/lip of the bedside? Hope that questions makes sense. Thanks!
  6. Jul 5, 2018 at 6:09 PM
    #106
    NMTrailRider
    New Mexico
    Yep I think that's correct. I'd recommend attaching the brackets to the bed extender and then hold it in place on the truck. Helps to have two people. Move it around until you have it level and positioned in a good spot where you will mount the brackets (use the measurements as a rough guide).
    When you have it where you want it, mark the top and one side with a piece of masking tape. Then remove the brackets from the extender and tape them back in place. Use a center punch through the holes to mark your drill holes. I highly recommend using a punch.
  7. Jul 5, 2018 at 6:14 PM
    #107
    LocoLocal
    Large American
    Thanks man! Going to try it this weekend.
    NMTrailRider[QUOTED] likes this.
  8. Jul 7, 2018 at 6:35 PM
    #108
    T8tjt
    T8tjt Well-Known Member
    Tom
    Las Vegas, NV
    2017, Inferno TRD OffRoad 4x4
    Nitro 5.29, Eaton Front Locker, Bilstein 6112 & 5160, RXT leaf pack, Cooper 33’s, Magnuson, CSF Radiator. Stay Tuned.
    The not sure what the dumbass at the dealer that installed it mine did, however, all the torx screws are loose and free spinning and one or two are missing. After 17 months of little use. Now what?
  9. Jul 7, 2018 at 7:28 PM
    #109
    NMTrailRider
    New Mexico
    Maybe he used a powered driver and stripped all the holes?
  10. Jul 7, 2018 at 7:49 PM
    #110
    T8tjt
    Tom
    Las Vegas, NV
    The one hole I see is perfect smooth. Will have to figure it out tomorrow, of course, it’s a friggin 110 out tomorrow. Are these simply sheet metal, self tapping type screws that are used???
  11. Jul 8, 2018 at 10:29 AM
    #111
    CampTruck
    Brooks
    NC
    Probably didnt install nuts on the backside. I dont think the original kit even comes with them. I recommend picking wome up from lowes. You can get the cap head bolts there as well. I believe I used M5 bolts washers and nuts on all of my holes. I also used permatex gasket maker on both sides of the holes on install.
  12. Jul 8, 2018 at 10:49 AM
    #112
    T8tjt
    Tom
    Las Vegas, NV
    I only took a quick glance at it before heading to work. Looks like the taillights have to come off to get access to the backside of the bed?
  13. Jul 8, 2018 at 4:37 PM
    #113
    CampTruck
    Brooks
    NC
    Affirm. Look at the beginning of this thread for the instructions. Super easy. Two bolts each then pop off.
  14. Jul 9, 2018 at 12:32 AM
    #114
    NMTrailRider
    New Mexico
    Are you talking about the brackets or the screws they actually hold the extender together?
  15. Jun 11, 2019 at 3:00 PM
    #115
    cmntaco
    cmntaco Well-Known Member
    Bill
    Denver, CO
    2017 TRD Pro (Cement, MT)
    Tires, RCI sliders, LED kit, tint, bed extender, tailgate lock, Tyger tonneau
    Thanks for the tips and write up.
    I scored a NIB one this week on CL. A local guy bought new OR and the dealer threw one in for free, it was in the box in back seat.
    He got home, then called to see if they'd install it free, they said "yes", so he dropped it off.
    When he picked it up, he noticed they overlooked the box in the back seat, and actually put in a separate one, so he had a spare he let go cheap since he got 2 for $0.
    The tips here were quite helpful, so thanks again!
  16. Jun 12, 2019 at 7:28 PM
    #116
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    I am glad that this thread surfaced again.
  17. Jun 21, 2019 at 4:43 PM
    #117
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    I just got mine now. These instructions suck.
  18. Jan 27, 2020 at 7:17 AM
    #118
    splash07s
    splash07s Well-Known Member
    Lauton
    Charleston, South Carolina
    2014 TRD Sport 4X4 DCSB White
  19. May 14, 2020 at 6:11 PM
    #119
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
  20. Aug 21, 2020 at 3:03 AM
    #120
    TahKo
    TahKo unofficial tinkerer & gadget/diy googler
    Christina
    New England
    2020 SR5, Barcelona Red, DBL Cab
    chrome rear letter inserts bed LED lights tailgate remote lock/un-locker side rails grill swap
    @adrenaline66 I stumbled across this forum.... Awesome write up, so helpful to have everything broken down with pictures!!
