OEM BED EXTENDER ON A 2008 DOUBLE CAB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Muskwa, May 18, 2012.
  1. May 18, 2012 at 12:51 PM
    Muskwa
    Muskwa [OP] I don't roll on Saturday
    Carl
    In a van down by the river
    08 DC SB SR5 TRD OFF ROAD
    I just got my OEM bed extender in, do I have to install those brackets that come with it or do I use those "bracket things" that are already installed, on the bed wall, by the end gate?
  2. May 18, 2012 at 1:01 PM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    I have no idea what your talking about but the bed extender uses two brackets, 1 on each side on the bed nearest the tailgate
  3. May 18, 2012 at 1:05 PM
    Muskwa
    Carl
    There's some brackets already installed where you say, are these factory installed for the bed extender? as the bed extender came with brackets and a template where I have to drill into the bed wall to install then, which I'm not to keen to do.
  4. May 18, 2012 at 1:13 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    Muska does it show you measurements on the template? I need to install mine w/brackets but dont know where to drill the holes, and I have no template as I bought mine used.
    thanks
  5. May 18, 2012 at 2:16 PM
    Muskwa
    Carl
    I can scan the template and email it to you if you want
  6. May 18, 2012 at 2:31 PM
    dpak
    dpak Well-Known Member
    Richmond, VA
    09 4x4 TRD Offroad DCSB
    Toytec/Eibach coils w/ 5100's set at 0, Toytec 2.0 Aluma Rear Shocks, Toytec Boss Leaf Springs, TRD Catback Exhaust, SCS F-5 Matte Gray Wheels, Elusive Elements Mesh Grill
    Did you purchase your truck new or used? If it's used, then the previous owner may have had a bed extender and already installed the brackets for you.
  7. May 18, 2012 at 4:41 PM
    Muskwa
    Carl
    I bought it used, the brackets that are already there look factory and don't match the brackets that came with the extender. ? .
  8. May 18, 2012 at 8:23 PM
    dpak
    Richmond, VA
    If the brackets look factory and you have a factory bed extender, then you should be good to go. Have you tried putting the bed extender in the brackets? Also, pics would be helpful. The brackets i used are not OEM but it works fine with my OEM bed extender. My brackets have a lever that releases the bed extender but i've seen brackets without the lever too.
