OEM Bed extender with mounting brackets.
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by WOTaco, Mar 25, 2016.
  1. Mar 25, 2016 at 11:08 AM
    WOTaco
    WOTaco [OP] Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    Came with my 2016. I already had one from my old truck so I've never used it. Should fit any Tacoma from 2012-2016. Mounting pivots included. Instructions and mounting template is available from AMP Research (the manufacturer of these).
    $150 buyer pays shipping or pick up in NY 12561. If it is to be shipped I will partially disassemble (as they come when purchased from AMP).
  2. Mar 25, 2016 at 11:21 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    :cool:
    You're about an hour to an hour & 15 minutes from me...
    Out of curiosity, do you know how this one compares to the OEM one?
    I might be interested. Been thinking about picking up one of these for a bit, just in case.
  3. Mar 25, 2016 at 11:25 AM
    WOTaco
    This is the OEM one, it came with my new truck.
  4. Mar 25, 2016 at 11:26 AM
    Cativelense
    Nuno
    CT
    Oh.. Oh, my bad. Thought this was an aftermarket one. Clearly I didn't read the tittle very well. My bad.
    Would you be up for possibly meeting half way one day?
  5. Mar 25, 2016 at 11:53 AM
    WOTaco
    Yea I'd drive a little. If you are near Route 84 I could head towards CT one day after work and meet you at an exit.
  6. Mar 25, 2016 at 12:37 PM
    Cativelense
    Nuno
    CT
    I'm right at 84 basically. I work in Danbury which is right over the NY state line. I'll PM you later then and we'll figure it out. At a doc appointment right now. Thanks a lot for being willing to do it!
  7. Mar 25, 2016 at 12:41 PM
    WOTaco
    Sounds good.
  8. Mar 25, 2016 at 2:14 PM
    mr4454
    mr4454 Well-Known Member
    2016 TRD OR 4x4 DBSB
    what would shipping be to 89014? thanks
  9. Mar 25, 2016 at 2:33 PM
    Cativelense
    Nuno
    CT
    Sorry man, already "bought" it. Setting up a meet so I can grab it.
  10. Mar 25, 2016 at 2:36 PM
    mr4454
    good deal, enjoy
    Cativelense likes this.
  11. Mar 31, 2016 at 1:01 PM
    WOTaco
    SOLD!
  12. Apr 5, 2016 at 12:13 PM
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    Those don't look like the OEM mounts. My OEM mounts came with actual nuts and bolts. Not just metal screws.
  13. Apr 5, 2016 at 12:55 PM
    Cativelense
    Nuno
    CT
    Probably because yours got installed at/by the dealer? It worked fine. Installed it this past weekend. I was the one that bought it from the OP
  14. Apr 5, 2016 at 2:34 PM
    stan23
    stan
    Santa Clara, CA
    No, I bought my OEM bed extender kit from a dealer. I'm sure the metal screws will work, but it is not as optimal as the OEM nut and bolt kit.
    More than likely what happened is the OP kept the OEM mount/nuts/bolts on his truck, and bought you a non-oem AMP mounts which uses the metal screws.
    Note the difference:
    OEM mounting hardware:
    Aftermarket mounting hardware:
  15. Apr 5, 2016 at 2:57 PM
    WOTaco
    Let's put this to bed. Pun intended. I have already explained this to the purchaser but I'll explain it here due to your concern.
    Those are absolutely the OEM mounts that came already installed with nuts and bolts on my brand new truck. Note the blue assembly paint around the holes. I purchased the lever style mounts you show above from AMP. They indeed came with sheet metal screws. I reused my factory nuts and bolts. I am using my bed extender from my old truck, sold the new one with the OEM mounts. Just threw in the screws from AMP and told purchaser he could through bolt them in the OEM fashion if he prefers. Is everybody OK now? Good eye Stan!
    wayneovermyhead and Cativelense like this.
