OEM bedliner
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stone56, Nov 26, 2024.
  1. Nov 26, 2024 at 12:39 PM
    Stone56
    Stone56 [OP] Well-Known Member
    Jeff
    2018 TRD Sport
    I am heading off on a two week hunting trip in the ANF in Pa. I took the bed mat out to clean under it and found that the bed was in great condition and is sprayed with a fairly rough material.
    If I am not hauling things to scratch and scrape the bed, and if the bed is sprayed with a rough surface to prevent slippage, is there any reason I shouldn't sell it?
  2. Nov 26, 2024 at 12:45 PM
    MGMDesertTaco
    bed mat? It keeps stuff from sliding around.
    kahanabob likes this.
  3. Nov 26, 2024 at 12:47 PM
    Stone56
    Jeff
    2018 TRD Sport
    Yes, mat, sorry. The spray in there does that just fine so I may be selling it.
  4. Nov 26, 2024 at 12:48 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Your bed is sprayed? with what? Our beds are Composite, fiberglass plastic stuff. They're usually pretty slick, which is why people like the OEM rubber mat.
    kahanabob, SH10151 and MGMDesertTaco like this.
  5. Nov 26, 2024 at 12:49 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Ice skaters do not need the skates to perform in the bed on that coating.
    Getting blood out of the rubber mat may be difficult, but that is the only reason you might hunt without it.
    YF_Ryan likes this.
  6. Nov 26, 2024 at 12:57 PM
    Stone56
    Jeff
    2018 TRD Sport
    Well sheeeit! It is plastic or fiberglass, looks like plastic. But it has a rough coat that things won't slide on.
    @RichochetRabbit That's a good point. I will leave it out for this trip.
  7. Nov 26, 2024 at 1:07 PM
    YF_Ryan
    Kent, WA
    I'm still curious on your bed... i've heard of people spraying them. Cause normally they are pretty darn slick. I've never heard of anyone ever saying that an OEM bed is grippy in the least.
    Some folks don't realize it's not a drop in bed liner though, so don't feel bad. It's pretty common for folks to not know there isn't a regular metal bed under there. :thumbsup:
    MagicToolbox likes this.
  8. Nov 26, 2024 at 1:16 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    A friend of mine is a big Ram truck guy. When I first got my Tacoma he could not believe the entire bed was composite and he crawled underneath to look.
    Here is a great test. Put a metal toolbox on your composite bed and drive around your town. At the end of your drive you know if you should keep your bed mat or sell it.
    PondScum and MagicToolbox like this.
  9. Nov 26, 2024 at 1:17 PM
    RichochetRabbit
    clang-clang ... two bells ... clang-clang-clang ... three bells ...
    Make the object low-lying if you have the plastic-cover bed lights at the back.
    YF_Ryan likes this.
  10. Nov 26, 2024 at 1:34 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Keep the rubber bed mat. The rough texture of the plastic bed won't keep stuff from sliding around.
    MGMDesertTaco and kahanabob like this.
  11. Nov 26, 2024 at 2:13 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    I'm thinking the OP bought used, and his bed was sprayed before he took ownership.
    Surely no one could mistake a factory bed for anything, but slippery af.
    Chew, GaMGMTaco and YF_Ryan[QUOTED] like this.
  12. Nov 26, 2024 at 2:39 PM
    jgarverick
    jgarverick Well-Known Member
    2021 DC SR
    Here here. Slippery AF is dead nuts accurate. Oh and if you spill anything oily on it good luck.
  13. Nov 26, 2024 at 2:42 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Not even sure why u would consider getting rid of it ? It’s not like it takes up space . Best thing I have ever purchased for the truck .
    MGMDesertTaco, Chew and YF_Ryan like this.
  14. Nov 27, 2024 at 6:57 AM
    wayne0
    wayne0 Well-Known Member
    After having an air conditioner almost blow my tail gate off then come into the cab, I'll stick to the bed mat!!
    Williston, Stone56[OP] and YF_Ryan like this.
  15. Nov 27, 2024 at 8:41 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    can't see the pics
  16. Nov 27, 2024 at 8:43 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Things will absolutely slide. Keep the mat.
    Stone56[QUOTED][OP] likes this.
  17. Nov 27, 2024 at 8:49 AM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Definitely...keep it!!!
    I have not put a toolbox to test it out but it sure is grippy. :D
    MGMDesertTaco likes this.
  18. Nov 27, 2024 at 8:49 AM
    Stone56
    Jeff
    2018 TRD Sport
    As it turns out someone did spray a rough coating but it is worn/slippery at the back. Therefore, I will be keeping the mat.
    YF_Ryan likes this.
  19. Nov 27, 2024 at 8:52 AM
    Williston
    Williston Unknown Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    My OEM bed mat is normally always in the bed mostly to keep things from sliding around and crashing into the front bed wall or tailgate on stops/starts. It's also way easier on the knees when you need to crawl around back there arranging stuff. If I make a run for bulk mulch, sand etc., or fill the bed with junk, brush, or firewood, I remove the mat or roll it up. I would definitely remove it before hunting or putting greasy or oily things on it, such as pick-n-pull car parts or a full oil change drain pan. (all of the openings seal good, but I don't trust it.) If I was dropping heavy rocks, cinder blocks or pavers etc. in it, the mat would be in place.
    The composite truck bed (2014) is in great shape. Some scratches but no divots or other damage.
    Chew likes this.
  20. Nov 27, 2024 at 8:57 AM
    RichochetRabbit
    Just in case people like the mat but not the price ... Tractor Supply Company "stall mat", $50. 4 ft x 6 ft ... cut side for the wheel-wells.
    Williston and TacoTime55 like this.
