OEM Blower Motor Resistor Wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jarett92, Aug 14, 2019.
  1. Jul 17, 2021 at 12:09 PM
    engdude758
    engdude758 Member
    2014 Toyota Tacoma 4x4 - Texas Edition
    Thanks for the detailed wire match up! Followed this to upgrade the old resistor and flat plug to the new style resistor with square plug. Worked perfectly the first time!
  2. Aug 11, 2021 at 3:41 PM
    rreed1900
    rreed1900 Member
    Bob
    Westminster, MD
    2015 Toyota Tacoma
    My thanks to everyone who provided info on this process in this thread. My blower motor was making a lot of noise and eventually damaged the resistor pack. So I ordered a new motor and resistor pack and got the newer style with the different connector. I wouldn't have been able to wire it in without the comments you guys made here. But I wired it up, tested it and everything was perfect. One thing I noticed is that since these motors wear out gradually over many years, we don't notice how loud they get until they reach the very end of this operational life. Then you drop in a new blower motor and you're shocked at how quiet it is.
    wiggler likes this.
  3. Sep 10, 2021 at 6:58 PM
    BG_Sea
    BG_Sea Member
    BG
    2012 4x4 dbl cab
    Antler scars on right side
    thanks for this - very useful today. Harness and resistor were $60 from Toyota at the parts counter.
  4. Sep 10, 2021 at 6:58 PM
    BG_Sea
    BG_Sea Member
    BG
    2012 4x4 dbl cab
    This post was clutch in getting my blower running on all four speeds again today. Thanks
  5. Sep 10, 2021 at 7:01 PM
    caribe makaira
    Caribbean, Puerto Rico
    :hattip:
  6. Sep 18, 2021 at 1:08 PM
    bermslider
    bermslider Well-Known Member
    Squampton, BC
    Double Cab 07 TRD Sport
    K&N Air Filter. 17" XD Revolvers wearing Hankook Dynapro ATM's 265/70/17 treads. Bilsteins in the Front set at 1.75". Debadged. Tail lights tinted.
    Thanks for the helpful post. I’m going to be doing this to my 07 DBCLB this week.
  7. Nov 11, 2021 at 10:08 PM
    goodend
    goodend Well-Known Member
    dave
    sw missouri
    2013dbl cab
    Where is the large rear plug?
  8. Nov 11, 2021 at 10:08 PM
    goodend
    dave
    sw missouri
    2013dbl cab
    Where is large plug to inspect?
  9. Nov 11, 2021 at 10:16 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    12TRDTacoma likes this.
  10. Nov 11, 2021 at 10:33 PM
    BLT2GO
    BLT2GO Well-Known Member
    2011 White Tacoma TRD TX
    I was having troubles with my blower either not working or only working on high so I got ready for surgery on my blower but when I investigated and unplugged and re-plugged the blower in, it worked! Between the plug being kicked and stepped on in the passenger footwell and issues with the pins and wires in the plug it just disconnects itself every so often.
    goodend likes this.
  11. Nov 24, 2021 at 8:49 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Thank you for this!
  12. Dec 14, 2021 at 10:48 AM
    TwistedTLM4
    TwistedTLM4 Unknown Member
    Philadelphia, PA
    '05 DCSB TRD Sport
    WeatherTech Floor Mats, WeatherTech Bug Shield and Vent Visors, Audio Upgrade, RaamAudio RaamMat & Ensolite, Mr. Marv's Custom 10" Sub Enclosure, Pop N Lock Electronic Tailgate Lock, mattgecko's Bedlights, Demello Offroad Single Hoop Bumper, Marathon Seat Covers, Leer Topper, OME885s on 5100s, @Blackout14 HD Leaf Pack
    Replaced my resistor with upgraded model, wired according to post #8 and working properly. Thanks guys!
  13. Dec 26, 2021 at 11:35 AM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    I replaced my dead blower motor resistor and the noisy blower on my 2010 in Feb with the Dorman kit . This week the fan started running only on HI, I'm hoping that it isn't the Dorman kit wire harness that has fried. I will get under the dash and check to see if it isn't seated completely. If not I will look into replacing it with this harness if need be. LAME!!
  14. Apr 27, 2022 at 8:58 PM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails, RokBlokz mud flaps WANT: Rear Plate Bumper, Steel bed cage
    Just did this upgrade/fix on my 2012 and it worked flawlessly. Here's to hoping the new style resistor and harness plug hold up longer than the original! THANK YOU for figuring out and sharing the wiring diagram!
    This has been a long-standing issue with my Tacoma. My fan speed started going out in 2017 and I finally replaced JUST the resistor with an aftermarket one (Dorman I think?) in late 2018. It worked for a while, until it failed again with the same issues in 2021. Clearly the wire harness had to be dealt with. I put up with the issue until last month when I ran across this thread detailing the new resistor/plug. I finally got the part in last week and replaced it today. It was a bit of a pain as I have never done any type of rewiring before. I had to buy the wire stripper tool and a heat gun for the crimping connector tubing, but it was worth it. The fan immediately worked on all four speeds after the fix.
  15. Jul 16, 2022 at 3:01 PM
    #35
    SeanTaco
    SeanTaco New Member
    2014 Silver Tacoma Prerunner
    I've had this issue twice already with my Tacoma, replaced the resistor twice but used the same harness. It was clear that the connector was burning up, so I got the replacement harness and resistor in and wired just like the posts in this forum are telling me.. Blower control is now working BUT... 2nd highest fan setting is blowing at level 3 speed and 3rd highest fan setting is blowing at level 2 speed! Level 1 and level 4 settings are working fine. ANY IDEAS????
  16. Jul 16, 2022 at 3:07 PM
    #36
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like you have a wire swapped at the resistor.
  17. Jul 17, 2022 at 12:36 PM
    #37
    SeanTaco
    SeanTaco New Member
    Yes, the wiring directions from previous posts did not work for me. I had to do the following:
    Old > New
    White w Blue > White
    White w Black > White w Black
    Green w Yellow > Blue
    Blue w Black > Green
    See photo. Everything works fine now.
    Dm93 likes this.
  18. Jul 17, 2022 at 12:39 PM
    #38
    SeanTaco
    SeanTaco New Member
    I also found a Youtube video where the wiring was different - if you're going to fix this issue in your truck, it might be a good idea to try a couple different patterns by just taping the splices together and testing everything before you start putting butt splices on and crimping.
    Singing_in_the_cab and Dm93 like this.
  19. Aug 18, 2022 at 9:08 PM
    #39
    emctrailrider
    emctrailrider Well-Known Member
    eddie
    Tempe, Arizona
    2013 4x4 DLCB TRD
    SPC Light Racing UCAs King Coilovers/Shocks Headstrong Offroad Progressive 3-leaf AAL 17x9 Fuel Offroad Krank Wheels 285/70/17 Nitto Ridge Grapplers Ultimate Lighting Upgrade Wet Okole Seat Covers Husky Floor Mats Black Oak LED 32" Lightbar
    I followed the first guys cross reference and nothing worked. I followed this cross reference and it mostly worked. My two middle speeds are swapped so I still have to dick around with it which i won't do now. It's hot AF in Phoenix so this shit will need to wait till November. That said, this was a very helpful thread, so thanks all who contributed. I'll post my final configuration to help the next guy. Leave it to Toyota to fuckup something so simple. It amazes me how they've dominated this truck segment of the market when honestly the trucks are built cheap as shit.
  20. Sep 6, 2022 at 4:28 PM
    #40
    dontnonottin
    dontnonottin Well-Known Member
    Larry
    Weigelstown PA
    2004 Toyota Sequoia Limited
    Just did our 2012 tonight.
    Here is what work correctly for ours:
    Old Harness -> ->New Harness
    White/Blue Stripe -> (Hi) -> Solid White
    White/Black Stripe -> (Lo) -> White/ Black Stripe
    Green/Yellow Stripe -> (M1) -> Solid Green
    Blue/Black Stripe -> (M2) -> Solid Blue
    Thanks to @Choads for posting this wiring.
