OEM Blower Motor Resistor Wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jarett92, Aug 14, 2019.
  1. May 10, 2023 at 7:37 AM
    #41
    Canada_Yoda
    Canada_Yoda New Member
    Brad
    2012 Tacoma
    Big thanks to all as this just happened to my 2012 tacoma yesterday. Buying parts shortly but it turns out Toyota now carries the adapter plug sold separately of course to accompany the air flow resistor.
    But again thanks to all.
  2. May 19, 2023 at 1:01 PM
    #42
    Jay9777
    Jay9777 Member
    Jay
    2005 Red Tacoma 4x4 5ft Manual
    Just finished installing old harness to new harness using this method and worked perfect. Thank you Choads.
  3. May 19, 2023 at 3:45 PM
    #43
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Just did this and it worked for me.
    Pabloeeto likes this.
  4. Jun 1, 2023 at 7:11 PM
    #44
    Charn Gill
    Charn Gill Member
    Charn
    2007 Tacoma double cab trd sport
    Can confirm. This is the way. Just did it on my 2007 Toyota Tacoma. 23/06/01
  5. Jun 30, 2023 at 2:47 PM
    #45
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    Just wanna thank y'all for the info, I just got done doing mine. I wired it incorrectly the first time just going by the a b c d layout on the connectors and had the two middle speeds swapped. It's all good now.
  6. Feb 9, 2024 at 8:17 AM
    #46
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    All I can say is Thank You, for all this information as I’m going through this right at this very second, lol
    nightcrawler likes this.
  7. Jun 8, 2024 at 6:05 AM
    #47
    nightcrawler
    nightcrawler Well-Known Member
    ‘17pro
  8. Jun 8, 2024 at 6:27 AM
    #48
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    Had to do mine last month. Easy stuff
  9. Jun 8, 2024 at 6:56 AM
    #49
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    High speed is direct so the resistor is not carrying the load the ideal is to have at least one speed for defrost/heat no matter what. Every step changes the resistance hence the speed except for high. On low it is a pretty good current draw so any poor connection creates and even greater current draw and tends to melt things.
    Dm93 likes this.
  10. Jun 8, 2024 at 7:00 AM
    #50
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    High speed will kill the switch eventually especially if you use it alot as all the current for high has to go through the switch.
    https://www.tacomaworld.com/threads...lay-mod-prevent-blower-switch-failure.827331/
  11. Jun 8, 2024 at 7:09 AM
    #51
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    It all ready does. It takes X current to run the blower no matter what speed so when you change to a lower speed the motor still has the same current draw plus a greater resistance to slow it down to a lower speed. It's not for nothing the resistor is right in the air stream it gets hot!
  12. Jun 8, 2024 at 7:37 AM
    #52
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes there is still current going through the switch on the other speeds but it's lower than on high speed and doesn't cause much issue, the resistor gets hot because it's dropping voltage across it and voltage drop (resistance to current flow) in a circuit generates heat.
    Pretty much all the blower switches I've seen failed have been on the high speed leg unless they run high through a relay.
  13. Jun 8, 2024 at 7:41 AM
    #53
    vtdog
    vtdog Well-Known Member
    NH
    I have done my 2011 twice. The first replacement was with an ebay part. That fix lasted only 10 weeks. The second fix was made using OEM part from on-line dealer. That part has lasted over 3 years without issue. Although it is an easy fix, if it breaks again I will probably have to pay to have it done. I don't think that I can "pretzel" myself anymore between the seat and the dash as my back seems to have a recurrent issue. Still though, an especially easy fix with the new plug.
    #53
  14. Jun 8, 2024 at 9:41 PM
    #54
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    As resistance increases, current decreases.
    As resistances decreases, current increases.
    You'll have more current on the High speed switch terminal, then you will on the lower speed terminals.
  15. Aug 26, 2024 at 2:46 PM
    #55
    Steveo2
    Steveo2 Active Member
    Hill Country, TX
    '11 TRD & '70 Vette
    My air speed control stopped working found multiple threads and seems to be a very common problem. Bought the new resister from Toyota for $40 this morn, but it has the square plug, damn, can't change it. Plugged the old one back in and it's working...WTF? Prolly wont work correctly for long so I plan to get the proper pigtail. Here is my question - Why would the flat connector be an issue?? Thx
  16. Aug 26, 2024 at 6:59 PM
    #56
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The stock flat connector has connection issues so they updated it to the newer square connector & resistor (per TSB 0062-21) that don't have as many issues.
  17. Aug 27, 2024 at 6:07 AM
    #57
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Have a good look at where the wire connect to the resister and make sure there are no signs of over heating on any of the resister pins.
  18. Aug 27, 2024 at 6:50 AM
    #58
    Steveo2
    Hill Country, TX
    '11 TRD & '70 Vette
    I get that but my question was why would the square connector cause the issue??
  19. Oct 3, 2024 at 12:42 PM
    #59
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    I just picked up the square updated one today. I've ran through two cheap replacements.
  20. Jan 9, 2025 at 1:34 PM
    #60
    MyBlackTacomaTruck
    MyBlackTacomaTruck New Member
    2006 TRD 4x4 crew cab 6 spd w diff locker
    400w Inverter mod, blower resistor mod
