OEM brake pad kit part number/difference question
Discussion in '1st Gen. Tacomas (1995-2004)' started by fazeka, Jun 30, 2016.
  1. Jun 30, 2016 at 1:06 PM
    fazeka
    fazeka [OP] Member
    2004 Tacoma 4-door crew cab, 2.7L 4-cylinder
    Bone stock
    Hi,
    Long time Tacoma driver, first time poster. :)
    I have a 2004 Toyota Tacoma Prerunner 4-door crew-cab 2.7L 4-cylinder pickup. Approx. 110k miles.
    Need to change out the front disk brake pads. Want to go OEM if for no other reason I don't want any surprises if that makes any sense... :)
    In doing my research, I see that there are two possible that may fit. One source says 04465-04040, the other 04465-04050. :confused:
    Anyone know which one is "right" for my particular truck or what's the difference between the two?
    BTW, I don't intend on pulling the calipers off to do the pad slap (I understand it is possible to slap in new pads without removing the calipers - TRUE?).
    Also, I was thinking about replacing the the pins, clips, pad support plates and inner/outer anti seize shims while I was in there. I see it as cheap insurance. Do you think this is overkill?
    Thanks in advance.
    Cheers,
    Paul
