OEM Car Play Solution for 2016 and 2017 models
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacomoboy69, Feb 7, 2023.
  1. Dec 24, 2023 at 6:04 AM
    #101
    rdgm71
    rdgm71 Well-Known Member
    Richard
    Florida
    2018 Black Toyota Tacoma OR Double Cab Short Bed 2WD
    Yes, sorry. You do so by using the controls on the steering wheel that give access to all the information on the instrument cluster like settings, tire pressure, etc. If you scroll right and left thru the different options, you will see one for music indicated by the simbol, you select that and will get a submenu for all the different music sources. If you press “FM”, you will then have a list of your preset radio stations, once you select one you will start listening to it while having CarPlay on you HU. You will need to have the CARabc screen already on the HU for this to work.
    slowpoke16taco and VicNic3 like this.
  2. Jan 22, 2024 at 4:44 PM
    #102
    Martymed
    Martymed Member
    SoCal
    Tacoma OR 4x4 SunRoof JBL
    Does anyone know what the boot time is for the carabc unit? Just wondering to know how long to allow to hit reverse and not black screen. Does it still send the song and artist title to the screen I the instrument cluster?
  3. Jan 22, 2024 at 4:45 PM
    #103
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    It doesn't transfer any information to the instrument cluster screen. Boot takes maybe 10-20 seconds
    Martymed and MofongoTaco like this.
  4. Jan 22, 2024 at 9:15 PM
    #104
    Martymed
    Martymed Member
    SoCal
    Thanks Saturnine!
  5. Jan 24, 2024 at 6:18 AM
    #105
    BadDogMax
    BadDogMax Well-Known Member
    IdahoLand
    2019 TRD Pro
    I just tested it: once the CarABC logo appears, you can go into reverse and the backup camera works as normal. CarABC continues booting up while you are reversing, even though you're looking at the camera and not the bootup screen. You don't have to wait for full bootup of CarPlay to go into reverse.
    The logo appears between 5 - 6 seconds after starting the truck. That's the minimum time to wait before driving if you want Carplay to appear automatically (like my wife's Rav4 with factory CarPlay does. The Rav4 CarPlay appear instantly either, but it can't be interrupted by reversing too soon).
    This unit has continued to consistently connect wirelessly every time I get in the truck. I am pretty happy with it overall. The only issue I can't seem to solve is matching audio levels between Siri, navigation, and music & podcast apps. Navigation and Music can be balanced using the Settings screen in the CarABC menu (I have navigation maxed at 18 and music at 13), but Siri has a mind of it's own and is often very soft. If anyone knows how to turn that up I would appreciate the help.
    Martymed likes this.
  6. Jan 24, 2024 at 1:29 PM
    #106
    Martymed
    Martymed Member
    SoCal
    Thanks BadDogMax! I can live with 10 seconds even. 5-6 seconds even better!
  7. Jan 27, 2024 at 3:04 PM
    #107
    RyoTGZ
    RyoTGZ Member
    Indiana
    This might be a lengthy post. I tried the CarABC unit mentioned in this thread and a different model from CarSyncTech (CST).
    https://www.amazon.com/2014-2019-Definition-Resolution-Mirroring-Compatible/dp/B0CB2ZR6QZ
    Edit: Here's the install video they linked to in the install maual: https://www.youtube.com/watch?v=4thtJXk-bv8&t
    I left an Amazon review that is pending review so it isn't live yet. So I'll post my summary here for those interested if the extra $100 is worth the upgrade.
    Summary
    *Yes, this unit is more expensive than the CarABC Carplay / Android Auto unit. But the screen resolution on the one from CST is much higher (no blurry text or images).
    *CST is also more responsive as I often times found sluggish behavior on the CarABC unit.
    *CST can be configured to use the factory unit Bluetooth or AUX audio sources. Bluetooth can be used so that map nav directions still happen even if using the car radio. I still prefer AUX though.
    *CarABC had to fully load before I shifted into reverse. Otherwise it had issues with displaying the rear camera and may not load Carplay after shifting back into drive. CST does NOT have this issue and is a big advantage for me at least. I had a hard time trying to remember to wait until I backed out of the garage.
    *The CarABC unit locked up on me a couple of times and I had to turn of the truck for it to work again. I've only had the CST version a few days, unable to comment on this.
    *CST does NOT intercept the voice button. It triggers both Entune voice and Siri at the same time. But you can press the top phone button to bring up Siri. I guess not a giant issue, but is annoying.
    *To bring up CarPlay or go back to factory, you press and hold the home button.
    *I could not get phone mirroring to work on either unit. CST support says they are aware and hoping to fix. We'll see.
    *CST support was very responsive to my questions. After first installing, the touch screen didn't work. They emailed me a firmware update and it worked fine after that. Shrug.
    *The CST install process is more complicated than CarABC. You have to remove the screen and replace a ribbon cable so that it can overlay its video over the factory. But my oh my, does the video quality look better. My Wife even said it looked a lot better.
    *Both CarABC and CST auto load when starting the truck.
  8. Feb 7, 2024 at 1:08 PM
    #108
    jyctaco
    jyctaco Well-Known Member
    Jon
    Portland, OR
    2017 TRD Offroad, DCLB - Barcelona Red Metallic
    I had the CarABC and returned it for every reason you listed. I’m very interested in ordering this after your review, so thanks!
    Is there any audio lag when connected via Bluetooth to the CarPlay software? What about when connected via wire? I prefer to use my fast charger so the wireless option is preferred. Thanks in advance
  9. Feb 7, 2024 at 2:29 PM
    #109
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    This looks great and I'll likely buy it. I plan to use it mainly for Spotify and Google Maps. Any opinion on how those work on Carplay?
  10. Feb 7, 2024 at 3:17 PM
    #110
    RyoTGZ
    RyoTGZ Member
    Indiana
    I have only used wireless when connecting. Their recommended method is to use the factory Bluetooth as the audio input source. It will have the same delay or lag as you see with entune today. This also requires 2 Bluetooth connections, one to the factory unit and one to carplay. This method seemed clunky to me.
    I mainly use Bluetooth to the carplay unit as the audio source with the factory audio input set to AUX. There is still a couple second audio delay happening there as well. And only one Bluetooth connection to carplay.
    There are some quirks, which I expect with an unofficial addon. But I'm willing to put up with them over Entune.
    My Amazon review is live now, I recommend reading it for additional details.
    jyctaco[QUOTED] likes this.
  11. Feb 7, 2024 at 3:22 PM
    #111
    RyoTGZ
    RyoTGZ Member
    Indiana
    Google maps works just fine. Looked just like it did in a rental I had a few months back. The apple maps work well too. I go back and forth on which I like most.
    I no longer use Spotify, only apple music and the sirius xm app. Sirius has some small issues that seem to be app related though.
    RX1cobra[QUOTED] likes this.
  12. Feb 8, 2024 at 6:18 AM
    #112
    fuzzynet
    fuzzynet Active Member
    James
    Tempe,AZ
    2017 Blazing Blue Tacoma TRD 4x4 Offroad
    Fuel Wheels,Nitto Tires
    How does the mic sound with carplay? Some reviews I have read online say when you call someone they can't understand you.
  13. Feb 8, 2024 at 4:35 PM
    #113
    RyoTGZ
    RyoTGZ Member
    Indiana
    No one has complained about the audio quality during a call. I haven't been on the receiving end though. That said I didn't have any complaints with either unit.
  14. Feb 18, 2024 at 10:15 AM
    #114
    gauchomigo
    gauchomigo Member
    dd
    2017 Inferno TRD Sport, Pro Grill, KDTune Max, Clazzios
    Hmm. "Unavailable" now on Amazon...
  15. Feb 18, 2024 at 11:46 AM
    #115
    calzonical
    calzonical Without the 2nd, there is no 1st.
    2018 Taco TRD OR DCSB A/T
    Decoder is also available from carsynctech website
    gauchomigo[QUOTED] likes this.
  16. Feb 18, 2024 at 12:39 PM
    #116
    kbUSMC2012
    kbUSMC2012 Well-Known Member
    Kevin
    2019 TRD Off Road 4x4
    Damn I was thinking about buying one too…
  17. Feb 18, 2024 at 1:11 PM
    #117
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    It'll be back
  18. Feb 18, 2024 at 1:59 PM
    #118
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    This is a timely post.
    I finally gave up on my module. I wanted to really like it but I found that I was rarely using it outside of the screen mirroring so that my kids could watch YT videos on the way to school. The audio quality in playback with the soundstage issues had me more often than not going back to Entune.
    The nail in the coffin for me was that the module was generating noise on my left front channel. As soon as I would put the truck into accessory mode I would sporadically get some level of noise in the front speaker. It would gradual increase in volume to the point I could hear it over phone calls on Entune and talk radio. It wasn't every day that I would hear it, but I'd hear it more often than note. I bypassed the module and this static disappeared.
    I really like the idea of CarPlay and having Waze / Spotify, but there were just enough issues with mine that I'm done. I'll be fully removing it from my truck in the next few weeks and selling on the module. Entune doesn't bother me enough that I'm in the market to replace it with a proper HU, but it's still annoying.
  19. Feb 18, 2024 at 11:43 PM
    #119
    jyctaco
    Jon
    Portland, OR
    I just installed mine and it looks good. However, I just lost my regular GPS maps and got this error. Other than that, it works. I’ll have to check out the forums and see for the fix.
  20. Feb 20, 2024 at 7:09 PM
    #120
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I had the same error
