OEM Coil question
Discussion in 'Suspension' started by TacomaJay09, Jun 6, 2014.
  1. Jun 6, 2014 at 6:54 AM
    TacomaJay09
    TacomaJay09 [OP] Well-Known Member
    Central MA
    09 TRD Sport Dbl Cab
    None Yet
    Does anyone know if an oversized shock like an OME Nitrocharger would have any fitment issues with a stock coil? I'm assuming that the diameter of the stock coil is the same any aftermarkets like 884's/885's but would like to make sure. Also, does OME make a stock replacement coil with the same ride height? Thanks, Jay
  2. Jun 6, 2014 at 8:19 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Well if you use the Billy 5100's for an example you can use your stock spring or either of the OME springs. So to answer your question. Yes the OME coils are the same diameter as the stock ones.
