OEM Cruise Control install for '10 Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vrbas, Jun 9, 2010.
  1. Jun 9, 2010 at 1:52 PM
    Vrbas
    Vrbas [OP] Well-Known Member
    2013 4x4 DCSB 6speed
    So i'm getting a Tacoma but the one thing it lacks is cruise control. The dealer said they could put an aftermarket unit on there for about $500 so i was like forget that.
    Anyways, i found a write up a few years back for installing the OEM cruise control on a Tacoma. However, that was way back in like '06. Here's my questions:
    - Does that writeup work for a new 2010 Tacoma (4 cyl, 5-speed)?
    - Where can i order the correct parts?
    - If it doesn't work, how can i make it work?
  2. Jun 9, 2010 at 2:11 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    I'm in the same boat, same truck. From what I've read here and on Toyotanation, it seems as though it's hit or miss at best, and it may even be impossible to install OEM cruise on our trucks. Check this thread out, and if you do manage to convert yours with success, pass it on!
    www.toyotanation.com/forum/t171992.html
    Edit: Shit, I think I just gave you the ame link you already posted. Good luck!
  3. Jun 9, 2010 at 6:31 PM
    Vrbas
    bump
  4. Jun 10, 2010 at 9:30 PM
    Vrbas
    bumpity bump
  5. Jun 11, 2010 at 7:19 AM
    Vrbas
    dang, guess there's been no luck with this one.
  6. Jun 11, 2010 at 7:41 AM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    isn't it the same cc that's been on toyota's for years?? i installed one in a toyota recently for about $60. it was very simple... i take it you haven't found any info on the internet?
  7. Jun 11, 2010 at 7:44 AM
    woodygg
    So Cal
    04 DC Tacoma 4x4
  8. Jun 11, 2010 at 12:57 PM
    Vrbas
    Sheesh, that looks much more complicated than the writeup i found. Granted it may have to be done if mine doesn't come prewired. Thoughts?
  9. Jun 12, 2010 at 10:05 AM
    Krusey1011
    Krusey1011 Well-Known Member
    Kyle
    Washington
    My cruise control just popped iteslf apart. noticed it at 36,300 miles (Just after the 3 year 36,000 mile warranty). BS! It's like it was set on a timer. Toyota wants $99 just to look at it. :eek: Forget that! It looks like it just popped out at the end. all the peices seem to be there. I cant really seem to find out how it's put together. Looking now :pccoffee: I don't use it to often but I use it. Definitely want it back.
  10. Jun 12, 2010 at 10:18 AM
    10taco
    10taco Well-Known Member
    Massachusetts
    '23 4X4 DCSB V6 AT SR5/SX MGM
    I bought mine online for a little over $100. It was in and working in less than 15 minutes. Found all that I needed (including the correct part number and instructions) on this site & T-nation. IIRC there are two different versions of this 'stalk' and one will make the delay(s) run backwards from the indicated setting; I'm not able to research it right now but it shouldn't be too hard to find. Good luck!:D
  11. Jul 28, 2010 at 6:13 PM
    demnemisis
    demnemisis Well-Known Member
    Dahlonega, GA
    Tacoma Base 4X4
    Worked perfectly on mine in less than 15 minutes
  12. Dec 2, 2010 at 5:45 PM
    msr237
    msr237 New Member
    Central PA
    '10 Tacoma Reg Cab Work Truck
    Just successfully installed cruise in my 2010 Tacoma Reg Cab Manual transmission, 4 cyl (work truck, not the SR5). I had done the install on an '08 in the past, but that's when they were prewired - it was a piece of cake. My '10 was not prewired with anything, but I purchased the kit along with the clutch switch from thecruisecontrolstore.com, closely followed the instructions and it works! It was a little more invasive than I was comfortable with (it being a brand-new truck), but I was just very careful with the instructions and all went well. I won't say it's easy, but if you're somewhat handy and can follow instructions, you can do it.
  13. Dec 3, 2010 at 8:23 AM
    Kilo Sierra
    Kilo Sierra Member
    Alaska
    4x4
    Congrats...
    I am considering the same product, and your info makes me feel a bit more comfortable.
    Could you show a picture of how the finished install looks. I am interested in the trimming required for the stalk. Did their template provide the correct location and size?
    Additionally, does your dash icon light up when you use the cc?
    Thanks for your time.
    ks
  14. Dec 3, 2010 at 8:58 AM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    msr237- this is good news! I read the instructions, and I like how everything is there for you, including the correct pin-outs. I would also like to know if the dash lights operate correctly, please let us know.
    Also, when I go to check out, it charges me +$35 if I choose the manual trans option. Is this for the clutch switch? Thanks :D
  15. Dec 3, 2010 at 5:32 PM
    j31driver
    j31driver Active Member
    chris
    upstate NY
    09 Tacoma
    Yes the extra charge is for the clutch switch and wires for the switch. I went this route on my 09 3 months ago and it works perfect. The dash light does come on as well.It took me 2 hours but I took my time and double checked every thing. Well worth it.
  16. Dec 3, 2010 at 5:48 PM
    msr237
    msr237 New Member
    Central PA
    I didn't use their instructions for trimming the steering wheel cover. I had purchased the cover from the link in the original post. The stalk from the Rostra kit (the one I bought from thecruisecontrolstore.com) is OEM as well - very nice. I can send you a pic if you want, but it looks totally OEM. Yes, the dash light works as well. I was pretty discouraged after reading alot of posts saying that cruise most likely wasn't possible on these trucks, so I'm sure you can understand how stoked I was when I pushed that button and saw the light come on! Then took it for a spin and all worked!!!
    Yes, the $35 is for the clutch switch and associated wiring. It's a good kit. The instructions are not the greatest for tearing apart the vehicle, but the pinout information was spot-on. The instructions I received said '09 at the top, but the pinouts were the same in my '10. Had a great trip to work this morning with my new cc!!!!
    I'm happy to help any way I can - let me know if you have any questions.
    (by the way, I'm a chick with no automotive electronics know-how, I'm just very determined and smart enough to carefully follow instructions when it comes to messing with my brand-new truck :)
  17. Dec 3, 2010 at 6:36 PM
    Kilo Sierra
    Kilo Sierra Member
    Alaska
    4x4
    Thank you....Nicely done.
    You have given me all the info I need.
    I am on the verge of buying a similar truck...Just in the process of arm wrestling about what I get for my trade.
    Also, many Kudo's for getting in there and getting this accomplished.
    ks
  18. Sep 21, 2011 at 7:42 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Sub'd
    Looking like $134 w/o shipping from toyotapartscheap.com w/o screws, w/ clutch switch.
  19. Sep 21, 2011 at 8:36 AM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    I wanted to let everyone know that I have had this kit installed in my truck for 8 months or so now, and it works flawlessly. Install took about 3 hours, was easy (good instructions). I couldn't be happier with this kit!
    All the lights work, and everything does what it should.
  20. Jan 3, 2013 at 9:07 PM
    TacoMan1911
    TacoMan1911 Well-Known Member
    LA
    2015 TSS DCSB Black DENALI EATER
    Worked great on my 08. $123.00 for everything and works perfectly!!
