OEM elocker replacement on 3rd generation?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mdmavity, Apr 8, 2018.
  1. Apr 8, 2018 at 6:22 PM
    mdmavity
    mdmavity [OP] New Member
    Greetings all
    I have been looking but only able to find an answer to this question for 2nd generation but can I just replace the carrier in my 3rd generation 4WD with a factory elocker from a 4WD donor vehicle or do I need to replace the housing as well? I looked at the parts manuals that I can find on line and the housing appears to be the same but I'm far from an expert. Obviously wiring us involved but I'm most concerned about how much of the rear end needs to be replaced to switch to an elocker differential.
    Thank You!
  2. Apr 8, 2018 at 6:53 PM
    trdt44
    trdt44 Well-Known Member
    Trent
    Utah
    2017 Tacoma TRD OR
    The elocker only comes in the 8.75" rear axle which is exclusive to the off road and Pro.
    Eta: Non offroad manuals may come with the 8.75" axle also.
    shakerhood likes this.
  3. Apr 8, 2018 at 6:55 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Different rears in 2nd versus 3rd rears.
  4. Apr 8, 2018 at 6:56 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    And manual Sport and SR5.
  5. Apr 8, 2018 at 6:57 PM
    shakerhood
    Southern Ohio
    You mean SR brother!
    hiPSI[QUOTED] likes this.
  6. Apr 8, 2018 at 6:57 PM
    Tacos in Gensokyo
    Tacos in Gensokyo Bohemian Archive in Japanese Red
    2017 SR 4cyl MT SSM
    Rokblokz Mudflaps, 2015 TRD Pro Suspension
    Was there a manual SR5? I thought the only manuals were Sport, Off-Road, Pro and SR.
  7. Apr 8, 2018 at 6:59 PM
    shakerhood
    Southern Ohio
    No Manual SR5, he meant SR
    hiPSI likes this.
  8. Apr 8, 2018 at 7:12 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Faux Pas... my bad.
  9. Apr 8, 2018 at 8:10 PM
    mdmavity
    Thank you gentlemen... I figured it wasn't simple :(
    hiPSI likes this.
  10. Apr 8, 2018 at 8:16 PM
    Bishop84
    Bishop84 Well-Known Member
    E locker sucks anyways, get an ARB air locker that actually turns on when you want it to.
    Toyota E lockers have to be engaged before the obstacle or its a pain to use it when you're actually stuck.
    Dirty Harry likes this.
  11. Apr 8, 2018 at 8:24 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Even if the diffs were the same, the wiring would be tough.
