OEM filters vs Competition
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lavrishevo, Jun 27, 2024.
  1. Jun 28, 2024 at 5:47 AM
    #41
    lavrishevo
    lavrishevo [OP] Well-Known Member
    2023 Trail Edition
    Try bumping up to 30 weight if you are using 20. Generally, vehicles begin consuming oil because of scoring along the cylinder walls. This is caused my carbon build-up and if the piston oil-ring begins to seize it will score the cylinder wall. I would personal flush the engine with a good cleaner and then switch to 5w-30 or 5w-40 based on what you are using now. You consumption is probably not based on oil filter choice, but in reality thin oil and allowing large particles to circulate is not a good thing.
    Barsoom and TA2016[QUOTED] like this.
  2. Jun 28, 2024 at 5:51 AM
    #42
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Rep said that because a K&N isn't a very good air filter until it gets dirty. It's kind of a known issue for K&Ns, their oil filters don't have a very good track record ether. I rate them right there with FRAM hugging the bottom.
    bgavin likes this.
  3. Jun 28, 2024 at 5:55 AM
    #43
    lavrishevo
    2023 Trail Edition
    The cheap Fram, yes, the Fram Endurance is an excellent filter.
  4. Jun 28, 2024 at 6:00 AM
    #44
    Trail Limo
    Trail Limo Well-Known Member
    As an engineer I read this different than you do. OEM is 16th in filtration but #2 in hot flow and #1 in capacity.
    Those numbers make me think that the smart engineers at Toyota analyzed what really matters to their engines and decided that flow and capacity are more important than absolute filtration abilities.
    Like others said once the media gets full, the bypass opens and then there is no filtration of the oil. Perhaps Toyota engineers decided that longer lasting slightly worse filtration abilities were not detrimental to longevity, and it is more important to ensure that the bypass valve never opens and the oil is always filtered.
  5. Jun 28, 2024 at 6:09 AM
    #45
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    It did not use a lot of oil but would drop below the top dot on the dipstick between oil changes toward the end. The RAV4 was my only Toyota I approached 200K miles, so my experience with higher mileage Toyotas is limited to that one vehicle.
  6. Jun 28, 2024 at 6:31 AM
    #46
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I change my air filters once a year in April whether they are needed or not because I’ve always done that and it’s a cheap purchase. As long as you change the oil filter every time your oil change I don’t think it matters what the brand is.
    2024OffRoad and Barsoom like this.
  7. Jun 28, 2024 at 6:31 AM
    #47
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    MMO soak will free up stuck piston rings. It is a common problem on Saturn cars, "Saturn piston soak" is all over the web.
  8. Jun 28, 2024 at 6:35 AM
    #48
    Barsoom
    NW GA OTP
    Lucky. I change mine every 2 months. And it needs it. I forgot it to do it once, and filter went for 4 months. Took a full day and all night for the ice to melt on the condenser coils.
  9. Jun 28, 2024 at 6:41 AM
    #49
    Barsoom
    NW GA OTP
    Another issue could be older seals. Do you have any oil seepage on the outside?
    LiquiMoly Motor Oil Saver can be added to any oil, and it will restore the seals.
  10. Jun 28, 2024 at 6:43 AM
    #50
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I solve that problem (frozen evaporator coil) in about 5 minutes by running the air on "on" without the cooling or heating on.
    t0p_d0g likes this.
  11. Jun 28, 2024 at 6:49 AM
    #51
    lavrishevo
    2023 Trail Edition
    The bypass valve is going to open mostly due to cold flow rates / viscosity or pressure at WOT. If you are clogging your filter, something else is probably going on or your running it for extreme periods. Toyota does make higher end filters and there is some debate about the quality when they switched manufacturing from Japan to Thailand. Engine longevity is by far mostly based on the quality of the internal parts and oil change intervals, not as much on filtration ratings, but I would still prefer to run a filter that catches more particulates.
  12. Jun 28, 2024 at 7:04 AM
    #52
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    My shop recommends NAPA Gold for those not wanting Toyota OEM filters.
    They also say to shun FRAM.
    BillF1564 likes this.
  13. Jun 28, 2024 at 7:19 AM
    #53
    Barsoom
    NW GA OTP
    Not an inch+ of solid ice
  14. Jun 28, 2024 at 7:21 AM
    #54
    BLtheP
    Plano, TX
    Has always solved any amount of ice very quickly.
    t0p_d0g likes this.
  15. Jun 28, 2024 at 9:03 AM
    #55
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    That’s what I implied in my post.
  16. Jun 28, 2024 at 9:49 AM
    #56
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Seems like peak filtration isn't the main concern for these toyota engineers. Maybe they need to watch more youtube videos
  17. Jun 28, 2024 at 9:50 AM
    #57
    Josephray70
    Josephray70 Well-Known Member
    Joseph
    Grand Rapids, MI
    2017 Toyota Tacoma limited
    Bilstein 6112/5100 at 2” (6/8 circlip, 3/8” top spacer, sway bar drop bracket, YotaWerx Black Hawk 2.0 tune, Borla Pro XS exhaust, Freedom Off-Road UCA’s, Alphrex Luxx Series smoked taillights, Westin bull bar, 265/65r18 Cooper Rugged Trek tires, 18x9 Anthem Off-Road wheels -12 offset, 4.5 backspace. Rock Sliders that I fabricated.
    Where can you get a Toyota filter for six bucks? Just bought one last week from Advance Auto for about 15 bucks
  18. Jun 28, 2024 at 10:09 AM
    #58
    Barsoom
    NW GA OTP
    $48.95 for a case of 10:
    https://www.amazon.com/gp/product/B007QVVV7M
    Sold by Conicelli Toyota.
    Under $5.50, with tax.
    I have ordered 2 cases from them. All filters were genuine OEM Toyota.
    Wife's RAV4 and Taco take the same filter, so I always keep some in the garage.
  19. Jun 28, 2024 at 10:17 AM
    #59
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
  20. Jun 28, 2024 at 11:00 AM
    #60
    Rusty66
    Rhode Island
    I paid seven bucks at the dealer.
