OEM floor mats
Discussion in '1st Gen. Tacomas (1995-2004)' started by brian1649, Feb 7, 2020.
  1. Feb 7, 2020 at 4:46 AM
    brian1649
    brian1649 [OP] Well-Known Member
    Hi all,
    Looking to replace the cheap Walmart floor mats that came with my new to me taco with some OEM ones. Not sure exactly what they look like, not what the interior color codes are so I need some verification.
    I've found these on eBay:
    https://www.ebay.com/i/153791333814...98772&itm=153791333814&pmt=0&noa=1&pg=2386202
    They look about right to me. I have a 2001 Xtra can with the "tan" interior. Is that the oak color code? Are there any better places to get the OEM mats or just crawl through eBay?
    Thanks,
    Brian
    GQ7227 and 2002Tacoma4x4 like this.
  2. Feb 7, 2020 at 7:52 AM
    1997tacomav6
    Denver
    eBay is probably a good place
    GQ7227 likes this.
  3. Feb 7, 2020 at 5:41 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Yes, those look like the OEM mats. In fact, they look like they might be Double Cab mats -- someone with an Xtracab will have to confirm that they're right for that body style. Perhaps they're interchangeable.
    Here's the interior of my 2003 when it had the oak interior it came with. (I changed the complete interior to charcoal from my 2001 before selling that truck.) I'm not crazy about the OEM mats because they don't have a heel pad. You can see where the previous owner of my 2003 wore through the mat completely with his heel.
    Even on my charcoal mats, which I babied as much as I could, were showing heel wear. I've cut checkerplate rubber sheet to the original pattern and have been using those for almost ten years.
  4. Feb 7, 2020 at 5:59 PM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
    These are what you want for easy cleaning and to really protect the carpet underneath-
    Do not slide and contain the trash
    Huskyliners original, a bit pliable.
    I have heard the OEM ones available (like pictured) don’t quite compare to the originals, in pile thickness or backing material and will dirty easy- great for a presale though-Weathertechs slide around and are hard plastic.
    jmo
