OEM Fog Light Install - Prewired
Discussion in '2nd Gen. Tacomas (2005-2015)' started by holeinone604, Nov 4, 2010.
  1. Dec 4, 2010 at 5:58 AM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    If you use the 3 prong switch, the fogs will still work, the problem is that the light won't. Most of the diagrams for your switch are set up for sourcing power to the relay, not sinking it. The issue is that if you source power, you have two resistances in parallel- the relay coil and the light bulb filament. This means that some of your 12 volts goes across each resistance- light turns on and coil and relay activates. If you sink power- you have 12 volts coming from the relay coil and the light is in parallel with the switch contacts (Approx 0 Ohms). In this case all of your power will go through the switch contacts and none will go to the bulb. The stock Toyota switch avoids this problem, since the illumination is independent of the switch contacts.
  2. Dec 4, 2010 at 6:26 AM
    SmoothFox
    SmoothFox Well-Known Member
    DFW TEXAS
    2010 TRD OFFROAD 4x4
    CBI Sliders,PIAA Lights, 5100's, 4 leaf pack.
    Subbed for future reference:D.
  3. Dec 4, 2010 at 10:03 AM
    holeinone604
    holeinone604 [OP] Well-Known Member
    Vancouver, BC
    16' TRD Sport Black Crew Cab
    Looks like I may be mixing and matching:(
    One stock OEM 2nd Gen on the pre wired fogs and the older rocker switch on the Hellas.
    I have done a bit of searching but do you know off hand if it will be easier to get an additional stock OEM 2nd Gen switch to work with Hellas?
    I have two of the rocker OEM switches on their way so if someone is interested I can probably hook them up for a good price.
  4. Dec 4, 2010 at 12:06 PM
    ILove2Drive
    ILove2Drive Well-Known Member
    Casey
    WV
    07 Tacoma 4X4 5 Speed Manual
    Halo headlights, Black tail light covers, dual exhaust, 5100s front and rear, eibach coils, wheelers 1.5 AAL, window tint, bow arrow antenna, bull bar, painted grille emblem, debadged, raceline rims, a few decals, CB radio, alpine HU, husky floor liners, tool box, mesh grill...and more to come eventually
    I'm wanting to put fogs in my 07 base model, I want to just stick to the OEM too, where is a good place to buy everything? I don't think there is anything pre-wired in my truck at all tho, correct?
  5. Dec 4, 2010 at 2:44 PM
    84Hilux
    Gary
    Vancouver, Canada
    OEM switch is plug and play for your present wiring. The light is on all the time and dimmed by the dash light dimmer. I saw a mod where a guy added an LED to the OEM switch, so it would change color when the fogs were on. About your Hellas- you will have to run the wiring to the fuse box and add another relay. The stock switch will work, since all the current goes through the relay, not the switch. You only want enough current to power the relay going through the switch. In this case, the problem is going to be finding the stock plug to go into the back of the fog light switch. I am trying to do something similar to add heated mirrors.
  6. Feb 19, 2012 at 6:38 AM
    bigwaverdr
    bigwaverdr New Member
    Bill
    Hanalei Bay Kauai
    08 Prerunner
    Bilsteen Shocks in front (level kit) K&N Air Intake, Custom Sound System
    Was that the wire coming out of your Dash for the switch for your fog lights? I have the same set up and I'm wondering if that's the wires for my Fog Light switch. My '08 Tacoma I guess is prewired. It has the wires for the lights behind the front bumper and that one set of 4 wires behind the Dash where the Fog Light Switch would go. Did it work out for you? Thanks
  7. Oct 24, 2012 at 9:35 AM
    froesen
    froesen Member
    Jon
    Chilliwack
    08 Dbl Cab SR5 4x4
    fog lights, OME Suspension (2inch lift all around)
    Thanks for all the information in this thread, I now have completed my first real mod, fog lights. Got the lights and switch from ebay and the relay from lordco. Work great, nice to have more light. Thanks everyone, I am not what you would call mechanically inclined, but it was straight forward based on this thread.
  8. Oct 24, 2012 at 9:45 AM
    Eddie98
    Eddie98 Active Member
    I need to add some to mine also
  9. Dec 28, 2012 at 8:50 AM
    cameron172
    cameron172 Well-Known Member
    VA
    2017 Super White TRD Sport MT
    Is the white wire that's tied on the grill above the bumper the prewiring for fog lights?
  10. Apr 9, 2013 at 6:39 PM
    NorCalTaco33
    NorCalTaco33 Active Member
    Ronnie
    Austin, TX
    2012 Tacoma TRD Sport
    Westin Side Steps, Fog light mod, Grillcraft grill, Future Mods: Stowaway Roof Rack, PIAA Lights, Lift 33" tires, UWS Toolbox, and many others...
    I take it no one has figured this out yet :confused:
  11. Apr 10, 2013 at 1:00 PM
    froesen
    froesen Member
    Jon
    Chilliwack
    08 Dbl Cab SR5 4x4
    cameron172 and norcaltaco33 that isn't the wire there. Lie under the front of your truck and look straight up between engine and bumper towards the truck not against the bumper. If it's pre wired you should see the wires for the fog lights tied off above and in line with where they mount on bumper, they have a plug already attached ready to plug into the back of the light bulb. the wires are running in a black plastic cover as well. hope that helps.
  12. May 20, 2013 at 9:46 AM
    cameron172
    VA
    It does! Thanks. Does anyone know what those random white wires are for?
  13. Aug 12, 2014 at 3:45 PM
    jtkkz
    jtkkz Well-Known Member
    Bay Area, Ca.
    2005 Tacoma DC 4WD
    OME lift kit / Fifteen52 Analog wheels
    I am doing the exact same thing for my '05 Tacoma, my truck is pre-wired as well.
    I did buy a factory switch from my local dealer for $42
    Do you need to buy a fog relay/fuse that gets plug into the fuse box inside engine compartment?
    What exact fuse/relay is it? part number?
  14. Aug 13, 2014 at 9:20 AM
    jtkkz
    Bay Area, Ca.
    2005 Tacoma DC 4WD
    Abragus likes this.
  15. Jul 16, 2016 at 6:56 AM
    #35
    MicahW95
    MicahW95 Member
    Micah
    2009 Toyota Tacoma TRD 4x4
    HID Kit Exhaust Mod Running light and side markers Led Conversion.
    Hello, I'm trying to do a HID conversion on my fog lights. I have a 2009 model Tacoma and can't seem to find anywhere on YouTube or on Tacoma world regarding the proper way to remove the fog light from the bumper. I can't seem to get it myself and struggling to find some good Intel. If someone could post a picture or video showing this it would mean a lot. Thanks
  16. Jan 28, 2017 at 2:05 PM
    #36
    chillymac
    chillymac New Member
    texas
    15 4x4 access
    2015 hooked everything up no power, which hole does relay go in?
