OEM Fog Light Switch and Hella 500's
Discussion in 'Lighting' started by Sua Sponte, Jun 24, 2013.
  1. Jun 24, 2013 at 3:43 PM
    Sua Sponte
    Sua Sponte [OP] Well-Known Member
    2013 Tacoma TRD Off Road
    Toytec/Bilstein Adjustable Coil Over (3") Bilstein 5100 (Front and Rear) Toytec 3" AAL Light Racing UCA's Toytec Diff Drop N-Fab Light Bar w/KC running lights N-Fab Side Steps Weathertech Floor Mats Toyota TRD Black Beadlock Style Wheels General Grabber AT2 285/75/R16 Other Stuff
    First time poster here, so forgive me if this has been covered somewhere already. I looked through some of the threads but didn't see any using this switch. I recently purchased some Hella 500 Driving lights to be mounted on top of my bull bar (picture below). I have a 2013 TRD Off-Road and all the blanks to the left of the steering wheel are taken up, so I wanted to find a switch that I could use for one of the blanks below the AC controls. I was able to pick up an OEM switch from the dealer (Part # 00016-32230-02) that is an exact fit for those slots for about 25 bucks.
    I want to wire these up so that they run independently from the fog lights, etc. Is there a tutorial on how to access/remove the center console to install the switch, as well as a general wiring diagram that would suit what I want to do? Thanks in advance.
    -1_zpsf0a9ee1d_94b16260e056670d677a866cc82cb5d655453d07.jpg-4_zpsb02a6e65_8e8d38274a5df4a1a4d9d52ec70841dd7eee439b.jpg-3_zpsc0c2cca6_d76c648e7c51830e706630d940917a8a932a6aa4.jpg
  2. Jun 24, 2013 at 3:49 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Did the Hella 500's not come with some basic installation instructions? I got some PIAA driving lights behind my grill and have an independent switch for them so I can turn them on and off whenever I want and they also turn off with the truck in case I forget to flip them to the off position so they dont kill my batteries. There was a write-up somewhere I looked at but its been about 4 years since I installed them. Look up on the top of the page where it has cheap/free mods and you might be able to find something on there.
    Edit: Just found this but not sure if its what you are looking for.
    http://www.tacomaworld.com/forum/technical-chat/6525-diy-wiring-after-market-lights.html
  3. Jun 24, 2013 at 3:53 PM
    Sua Sponte
    Thanks for the post. Yeah, there's instructions for them...not the most detailed. I am thinking I may need to mod the harness it came with to accept the OEM switch since the two connectors are different. Anyone know of a tutorial out there that would cover all of this...I.E. removing the console to get access to the blanks and harness, etc. Thanks.
  4. Jun 24, 2013 at 3:55 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I got an aftermarket switch that fit in the slots right of the steering wheel and I had to cut off the original switch that came with the PIAA's. It wasnt to hard to do but my truck is a 2006 and you are installing in a different area.
  5. Jun 24, 2013 at 9:12 PM
    Sua Sponte
    No one with any experience mounting a switch in the center below the AC controls?
  6. Jun 27, 2013 at 8:54 PM
    Sua Sponte
    Bump. Anyone?
  7. Jun 28, 2013 at 4:18 AM
    denmen
    denmen Well-Known Member
    Dennis
    New Hampshire
    2013 4x4 V6 SR5 6-spd Spruce Mica AccCab
    Tube steps, bull bar and KC Hilites, trifold bed cover, variety of shifter knobs, comparing LED strip options, lift possibilities (prob 2 inch), and exhaust mods to tune growling on low end...
  8. Jul 27, 2013 at 7:21 PM
    Sua Sponte
    Finally got around to finishing this. Not the best picture but oh well. I ended up ordering the tundrapart switch and used one of the blanks below the A/C controls. It was kinda a pain routing the wiring through the grommet in the firewall behind the front central console, but all worked out well. I also ended up buying a different harness from Pilot because the one included with the Hellas I just could not get to work.
  9. Jul 28, 2013 at 7:38 AM
    Sua Sponte
    And here is the installed switch.
  10. Jul 28, 2013 at 7:44 AM
    Valsmere
    Valsmere Well-Known Member
    Brian
    New Jersey
    EXPENSIVE
    tail gate lock, rear view mirror bracket, hood hinge brackets, and the list grows.
    Cool thanks I was looking for the same thing with the switches. My switch banks are filled up also. Thanks for posting the part number.
  11. Jul 28, 2013 at 8:17 AM
    Sua Sponte
    No problem, and yep, if your switches to the left of the steering wheel looks like this then the only alternative is to go below the AC knobs.
  12. Jul 28, 2013 at 2:07 PM
    Valsmere
    Brian
    New Jersey
    EXPENSIVE
    Oh yeah they are filled already with daystar switches!
  13. Aug 3, 2013 at 9:13 PM
    RaymanTRD
    RaymanTRD Well-Known Member
    Ray
    MI
    2013 TRD Sport 6-spd
    TRD cat back TRD quick shifter TRD skid plate bed extender
    How did u winded up getting behind that panel?
  14. Aug 4, 2013 at 3:52 AM
    Sua Sponte
    Through the hole in the firewall that the main electrical harness goes through on the drivers side. Then, behind the center console.
  15. Aug 27, 2013 at 7:37 PM
    ToxicPelican
    ToxicPelican Well-Known Member
    San Diego
    2012 DCSB
    How did you wire up the back of the OEM switch?
    Like you my bank to the left is all full, and I wanted to put an OEM switch that fit under the AC controls, so I ordered that same switch. Only thing is, looking at the back of the switch, its just 5 pins recessed waaaaay back into the switch? How the heck did you hook that up?
  16. Aug 27, 2013 at 7:55 PM
    ToxicPelican
    San Diego
    2012 DCSB
    This is what the back of mine looks like
  17. Aug 28, 2013 at 3:35 PM
    Sua Sponte
    You need the connector that goes into the back of the switch and ties into the wire harness for the fogs.
  18. Aug 29, 2013 at 7:20 AM
    ToxicPelican
    San Diego
    2012 DCSB
    Where were you able to find that connector or harness? I know what the part number for it seems to be, but no one wants to sell just the harness, they all want to sell the entire fog light kit.
  19. Aug 30, 2013 at 7:11 AM
    ToxicPelican
    San Diego
    2012 DCSB
    Actually don't worry about it, I'm going to go in a different direction for switches. Thanks though!
    *If anyone in the San Diego wants to play with this switch, it's yours just pm me, not worth it to return it
  20. Aug 30, 2013 at 7:56 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Subbed for part #
    And Pelican, if noone local takes you up on your offer, I'd be happy to paypal money for postage if you care to toss it in the mail.
    OP, do you have a part number for the other switch you put in on the right?
    I have the same switch configurations as you, and this would be perfect.
