OEM Fog light switch to Hella 500 or KC Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Unchained 5150, Feb 2, 2015.
  1. Feb 2, 2015 at 3:13 PM
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    So I know a lot of you are good at doing your own wiring and such and like aftermarket switches. I am choosing to add Hella's to my behind the grill mod. But want to use an OEM switch in the truck next to the other OEM switch. So I had and OEM insert made with the 3 wires coming out to go to the Hella's it is a plug and play insert no mod needed. Pics in a minute.
  2. Feb 2, 2015 at 3:15 PM
    Unchained 5150
    Rick
    Auburn Ma
    Some pics
  3. Feb 2, 2015 at 3:17 PM
    Unchained 5150
    Rick
    Auburn Ma
    The complete assembly. Just easier for those not that handy
  4. Feb 3, 2015 at 6:30 AM
    monkiboy
    monkiboy Well-Known Member
    I like how clean and OEM it is of a solution. so you will have two switches that are aesthetically the same now? interested to see it installed and perhaps ideally etch or sand smooth or wipe the existing graphic off, and get your own logo cut and apply to the switch for a truly interesting one-off better illustration of its purpose. eh? I'm sure we have to be able to buy switch blanks off of a Nissan electronics parts store somewhere.
  5. Feb 3, 2015 at 6:32 AM
    Unchained 5150
    Rick
    Auburn Ma
    Hmmmmmmmmmmmmmm never thought of that.
  6. Feb 3, 2015 at 6:54 AM
    monkiboy
    you have now :D
  7. Feb 3, 2015 at 6:55 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I had an OEM fog light switch running aftermarket lights. The only issue I came across was the inserts themselves are different so you have to shave the dash so it'll fit. The fog light switch has grooves so it only fits nicely into one location to the left of the steering wheel. A few minutes with a file or dremel is required to make it fit into one of the other spots. I believe the FJ Cruiser has a 'driving light' switch that is the same size as the fog light switch also. Another option is OTRATTW switches which can be etched to say just about anything.
  8. Feb 3, 2015 at 7:01 AM
    Unchained 5150
    Rick
    Auburn Ma
    So the blank next to my OEM fog light switch won't fit another exact same switch without modification
