OEM Fog Lights on 2009 ?
Discussion in 'Lighting' started by millette1968, Nov 21, 2008.
  1. Nov 21, 2008 at 8:10 AM
    millette1968
    millette1968 [OP] New Member
    Rockyford, Alberta
    09 Access Cab
    Has anyone done the OEM fog light install on a 2009 Taco ?
    I have a 2009, extended cab without the SR5 (its a spare vehicle), yet it has power windows, locks, etc.
    I want to do the fog light install. I have the wiring at the fenders, and the relay slot in the fuse block, but when I remove the blank (upper left) on the dash, there is no wire harness attached. I havent ripped the dash apart to do any digging in behind yet.
    Is this truck likely to have the wiring to the fenders, but not the wiring at the dash ?
    Interestingly the center blank, and the right blank both have wire harnesses attached.
    Is it just a two conductor switch, connector I am looking for ?
    Thanks in advance.
    Mods I have done.
    1. OEM cruise control installed
    2. OEM Intermittent wipers
    3. Wind/Shades on side windows
    4. Rock/Bug gard on hood
    5. Tri-fold box cover. Just love it !
    6. UsaSpec PA15-Toy ipod adapter. Having some problems with this one.
  2. Dec 1, 2008 at 7:24 PM
    wizo
    wizo Well-Known Member
    Port St. John, FL
    09 PreRunner 2.7L
    2.5" Walker Evans C/O's, All Pro UCA's,
    I also have an '09 but mine is a SR5 and am also interested and installing factory headlights. Hopefully someone can shed some light on this for us.
  3. Dec 2, 2008 at 5:09 PM
    VORTMAX_99
    VORTMAX_99 Member
    millette1968,
    I've got a 2009 access cab with the 4 cylinder/manual transmission
    and the convenience package. There is no wiring at all for the fog
    lights (either at the fender or where the dash switch would go).
    From what I've read...it appears that the 4 cylinders have no
    wiring for fog lights...though the 6 cylinder models do (and that
    may only be automatics...but I'm not sure).
    I see in your mods that you installed the intermittent wiper switch on
    your 2009. Can you tell me if that's the same switch as on the
    2005-2008 Tacomas? Mine came without it and I'd like to upgrade
    like you did. Have read on the boards that you can upgrade the
    2005-2008 fixed speed wipers to intermittent wipers by replacing
    the wiper switch/stalk. Can you tell me which switch you used or
    what part number it is?
    Thanks,
    George.
  4. Dec 2, 2008 at 5:47 PM
    the_tick
    the_tick Active Member
    Lake Mary, Florida
    07 Tacoma Reg Cab
  5. Dec 2, 2008 at 6:05 PM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
  6. Dec 2, 2008 at 6:15 PM
    patrickockander
    patrickockander Say What?
    Patrick
    San Antonio, TX
    TACOMA TRD Offroad version 4x4
    Supercharged, Hood Lift-struts, Borlas, 2-tone Leather, Husky Liners, 16" Completely rewired audio system, Components front/rear, Dbl Limo Tint, 2-din JVC KWNX7000BT (DVD+GPS), TRD CAI, disabled seatbelt alarm, E3 Plugs, Halo Headlights, Tuck-in style Rain guards, dealer sticker removed, Step rail,
    I'm in the same boat as the few of you...However, I just found a guy selling the OEM foglight switches on Ebay for $20 bucks...Here's the item number and link. I just ordered one myself. I figure worst case I'll completely rewire it if I have to.
    TOYOTA TACOMA OEM FOG LAMP SWITCH 05-09Item number: 300276244091
    If this link doesn't work, just cut and paste the item number into the search slot...he's got 18 left.
    http://cgi.ebay.com/ebaymotors/ws/e...m=300276244091&ssPageName=STRK:MEWA:IT&ih=020
  7. Aug 11, 2009 at 1:58 PM
    rustyg61
    rustyg61 Active Member
    Rusty
    Texas
    09 Double Cab, Speedway Blue
    Chrome front grille, cruise control, intermittent wipers, NASTA Nerf Bars. Fog Lights JVC Stereo Pioneer speakers
    I just got my 2009 Double cab last week & want to also add the wiper, cruise, & fog lights. Have you heard anything on if installing these yourself will void the warranty?
