OEM Front Brakes BS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pro-Taco, Aug 21, 2023.
  1. Aug 21, 2023 at 1:09 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I inspect at least every tire rotation. Also, if I’m doing any other maintenance that has a wheel off, I check as well.
    df41590 and Chew like this.
  2. Aug 21, 2023 at 1:21 PM
    lbhsbz
    lbhsbz Well-Known Member
    Either you live very near the ocean in CA or that truck spent some time in the rust belt over winter...rust consumed the rotor friction surface and abraded the friction off the pad. This is common in the rust belt...especially if the vehicle is allowed to sit for any period of time. Nothing wrong with the parts, its the environment and the usage (or lack there of).
    Junkhead, df41590 and Pro-Taco[OP] like this.
  3. Aug 21, 2023 at 1:28 PM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    Ive never had this happen that soon and live in the rust belt..
    turkeyslayer66 likes this.
  4. Aug 21, 2023 at 1:32 PM
    Pro-Taco
    Pro-Taco [OP] Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    I think you nailed it. I do live neat the ocean and I don't drive this truck often. Like I said I only have 22k in 4.5 years of ownership.
  5. Aug 21, 2023 at 1:44 PM
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    Like others have said, the caliper pins need to be cleaned and greased.
    Pro-Taco[OP] and Chew like this.
  6. Aug 21, 2023 at 2:22 PM
    Pro-Taco
    Lou
    Commiefornia
    All TRD Pro parts
    Yep, done that too.
  7. Aug 21, 2023 at 2:28 PM
    Trail_Limo
    Trail_Limo Well-Known Member
    G
    Land of fruits and nuts
    Turd Gen OR Limo
    Iam glad this came up, I noticed the brake pads on my passenger side wheel has prematurely worn down (enough for the squealer tab to cut a groove in my disc) while my drivers side pads have alot of meat left on them.
    I am replacing front brakes this weekend and paying close attention to the sliding pin..
    Did you crack open the brake fluid nipple before pressing in caliper pistons?
    I have never done that to any of the hundreds of brake jobs Ive done and have never had an ABS issue, but Ive read about it on these trucks?
  8. Aug 21, 2023 at 2:30 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    41000 on my 19, in the rust belt, and mine still look new. checked at 8000 mi rotations. sorry for your luck. vehicles sitting for long periods may save mileage on the odometer but, are harder on the vehicle maintenance wise, in some cases. water, wet, damp humidity, salt, add to that. Ski
    turkeyslayer66, Pro-Taco[OP] and Chew like this.
  9. Aug 21, 2023 at 2:32 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    yes!
    When I used to buy used,,, I was just as weary of low mileage, as high mileage,,, sometimes more.
    skidooboy[QUOTED] likes this.
  10. Aug 21, 2023 at 3:04 PM
    Pro-Taco
    Lou
    Commiefornia
    All TRD Pro parts
    Didn't crack the nipple. I don't think you need to. I do strongly recommend getting the proper piston spreader. It made the job so mush easier.
  11. Aug 21, 2023 at 3:18 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    After 3 Toyota trucks and always used oem pad and rotors never an issue with quality. You must have some sort of caliper issue.
  12. Aug 21, 2023 at 3:51 PM
    lbhsbz
    pins in this application have absolutely nothing to do with the problem at hand
    Pro-Taco[QUOTED][OP] likes this.
  13. Aug 21, 2023 at 3:52 PM
    lbhsbz
    There isn't much you can do to prevent rust on cast iron rotors except drive it. I wish there was a better answer but there's not.
  14. Aug 21, 2023 at 4:01 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    +1 I was going to say this exact thing the more people using their phones while driving the more I see a car going up hill with brake lights on.
    Chew and Bertw192[QUOTED] like this.
  15. Aug 21, 2023 at 5:59 PM
    #35
    newbbewb
    newbbewb Active Member
    D
    14 sport Doublecab
    Don’t discount a faulty brake house or a pinched hard line. Both can create a one way valve action…letting fluid in, but not out. Seeing the pad wear most likely a caliper issue. That blue tinting on the rotor and the glue in the pad material chunking off like that tell me it got hot af. For the mileage you have its shocking to see any of the pads worn down that much, but if one side isn’t working well the other side gets to do the work. I would replace front brake hardware, and visually inspect, clean, and adjust the rear brakes. Probably do a fluid flush as well. Get a temp gun and check new brakes after break in to determine if possible brake hose. This can happen with Toyota calipers, but is rather rare.
  16. Aug 21, 2023 at 6:12 PM
    #36
    Pro-Taco
    Lou
    Commiefornia
    All TRD Pro parts
    Noticed your signature says autobrakesolutions. I am guessing you deal with this type of stuff on a daily basis. Nice goodies you got there, I wish I found it sooner. Thanks for all the helpful answers!
  17. Aug 22, 2023 at 9:54 AM
    #37
    lbhsbz
    20 years in the business, 2 years on my own…I’ve seen a few things. Lol
