OEM front camera and Anytime Backup Camera Kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Got_boost, Jun 13, 2022.
  1. Jun 13, 2022 at 5:13 PM
    Got_boost
    Got_boost [OP] Member
    Colorado
    I have been researching and have not been able to find any info on making an OEM front camera work with the Anytime Backup Camera Kit (kit without camera). I recently had the dealer install the Toyota lift kit, which came with the Heritage grill. I removed my grill and noticed it had the wiring harness connected to a "dummy" camera so I added an oem camera from a 2021 Tacoma (My 2022 did not have a front camera). My thought was I would then add the Anytime Backup Camera Kit and be done, but I can't find any info on how to connect the oem camera. Any thoughts? I think the oem camera is 6 volts, which might also be an issue.
    brandon78lusch likes this.
  2. Jul 12, 2023 at 7:46 AM
    CMH2023OR
    CMH2023OR New Member
    Just found this post and am running into the same idea. I don’t like the Anytime camera protruding from the grill.
    I just ordered a different Natika camera from Amazon that’s closer to OEM spec and that should plug into the harness from Anytime.
    I’ll update you once I test fit it.
    Taco_mike73 likes this.
  3. Jul 14, 2023 at 11:27 PM
    CMH2023OR
  4. Jul 15, 2023 at 1:36 AM
    Matte Black burnt rust
    Matte Black burnt rust Well-Known Member
    2020 Tacoma TRD Off Road
    How's the lift?
  5. Jul 15, 2023 at 7:35 AM
    CMH2023OR
    Way better than stock.
    I’m sure there are better DIY approaches but for my “phase 1 build”, I want to keep things as close to OE+ as I can (this is how I do all my builds - E30, 912, etc).
  6. Jul 15, 2023 at 7:38 AM
    CMH2023OR
    Also - @Got_boost - after hunting and reading a lot of posts, I have not been able to find anything for the OEM 6 pin connector splicing into the Anyconnect harness.
    That’s why I went for the Natika.
