OEM Gear Ratio Chart
Discussion in '1st Gen. Tacomas (1995-2004)' started by chris4x4, Mar 1, 2015.
  1. Aug 21, 2019 at 9:34 AM
    #101
    Guitarzan_
    Guitarzan_ Member
    Dean
    NY
    '17 TRD OR DCSB
    Hey everyone, noob here. My rear diff just went, was leaking oil and seized up, so I need a new one. It had B03A in it, which looks to be 4.10 gears. MY truck is a V6. I'm assuming it doesn't matter if I find the same diff that came out of a 4 cylinder auto truck? Thanks in advance!
  2. Feb 18, 2020 at 11:40 AM
    #102
    HardTaco03
    HardTaco03 Well-Known Member
    Louisiana
    2003 Ext Cab 4wd 5 speed 3RZ
    So 2003 with 2.7L 5 speed 4wd code BO7A is 4.56 factory gears?
  3. Feb 23, 2020 at 6:25 AM
    #103
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    Mine is the same (B0A7) and I believe it is 4.30 gears
  4. Apr 13, 2020 at 9:18 AM
    #104
    The gold standard
    The gold standard Well-Known Member
    Western mass
    Green 03 v6
    According to the op, 4.30 is right. My 02 2.7 manual 4x4 has the same.
    ontarioyota[QUOTED] likes this.
  5. Apr 13, 2020 at 9:22 PM
    #105
    SethSA33
    SethSA33 New Member
    Seth
    2014 Tacoma Prerunner i4
    3 inch lift 285’s bed rack
    I need help my axle code is A02A and I put 33’s and now I need a bigger ratio. Can’t find any though. I have a 2014 Tacoma 2wd 2.7l prerunner.
  6. Apr 13, 2020 at 9:41 PM
    #106
    The gold standard
    Western mass
    Green 03 v6
  7. May 13, 2020 at 3:56 PM
    #107
    Gilliganthecat
    Gilliganthecat New Member
    Roy
    2000 tacoma 4x4 3rz manual.
    My 2000 2.7 ext cab 4x4 manual is BO6A 3.91 and
    My 2000 2.7 ext cap prerunner auto is BO7A 4.30.
    What is the other code you showed?
  8. Jul 29, 2020 at 9:55 PM
    #108
    Dylwhit
    Dylwhit Well-Known Member
    Dylan
    2004 2.7l extcab
    When i did my rear end I still did a manual check on the gear ratio because im a bit paranoid. Chalked the propeller shaft and the rear wheel, jacked her up on jack stands and had a buddy turn the rear wheel 10 full rotations. I counted 2.25 rotations on the propeller shaft and multiplied it by 2, which gave me a 4.5 gear ratio (4.56). You wont make it too far if you get
  9. Jul 29, 2020 at 9:57 PM
    #109
    Dylwhit
    Dylan
    2004 2.7l extcab
    You wont make it too far if you get the ratios mismatched....
    1stGenTaco4x4 and wilcam47 like this.
  10. Jul 29, 2020 at 10:12 PM
    #110
    Dylwhit
    Dylan
    2004 2.7l extcab
    Sorry folks, I need to correct myself again because I did my rear end a year ago and had a brain fart. If you want to manually check for gear ratio you can jack the truck up, chalk the wheel and drive shaft, pop it in neutral and spin the rear wheel 10 rotations. Video the propeller shaft and count the shaft rotations (mine spun approximately 22.5 times), multiply the rotations of the shaft by two (mine was 45ish) then you divide that number by 10 ( mine was 4.5ratio).
    Good luck with the rear end.
    Lukass likes this.
  11. Sep 1, 2020 at 4:11 PM
    #111
    Tacoma1997White4x4
    Tacoma1997White4x4 America First
    West Covina, California
    1997 white 4x4 auto 4cylinder Singlecab, 2001 auto rwd 2.4l single cab flatbed
    Km3’s 31’s,Lift,Sliders,rear ARB air locker,on board air, armor, hi shell
    Sorry to revive this thread but my truck says B03A
    I have an 8 according to the specs on the list, i have a 97 tacoma simgle cab 4x4 automatic
    ive heard of an 8.4, just want to make sure im 8 before ordering an arb air locker, thx
  12. Oct 23, 2020 at 10:29 AM
    #112
    LiftedOn35s
    LiftedOn35s Graduated!
    Noah
    Northeast FL
    Shadow Grey Met. 2004 Tacoma V6 5MT TRD OR
    1" level, 16" American Racing wheels, 32" M/Ts
    I think it was mentioned farther back, but the 8.4 was just what Toyota called the E-Locker diffs. They were technically an 8 though, so it's 8 for both the e-locker and non-e-locker diffs. Correct me if I'm wrong, just what I've heard.
    Lukass likes this.
  13. Oct 28, 2020 at 1:08 PM
    #113
    97Tacosupreme
    97Tacosupreme Member
    Phoenix Arizona
    Sr5 1997 rwd
    Did the 5 lugs ever come with 4.10 gears?
    Lukass likes this.
  14. Nov 3, 2020 at 3:32 PM
    #114
    LiftedOn35s
    Noah
    Northeast FL
    Curious about something that someone might know. My parents towed a ~3500lb Grady White boat with our 2001 PreRunner Xtra Cab AT V6. I asked him how it handled (I've heard the complaints of "oh these trucks are so bad at towing you feel anything you put on the back") and he said it was pretty easy and effortless, so I was wondering what the rear end might've been in it. I want a V6 5MT Xtra cab (and I intend to tow with it at some point) and I know they're all 4.10s, but I was thinking the PreRunners might've been different being 4AT vs a 5MT.
  15. Mar 29, 2021 at 6:04 AM
    #115
    Taco2021LB
    Taco2021LB Well-Known Member
    Don
    WA
    2004 DblCab 4x4
    OME 882 Dakars Falken 235/85R16s
  16. May 3, 2021 at 9:50 AM
    #116
    Jase
    Jase Well-Known Member
    jase
    Oregon
    2004 4x4 DC
    Rebuilt / frame swap at 200K
    Local junkyard telling me that a factory 4.56 rear end never came with an E locker, only the 4.30. Is that true?
  17. May 3, 2021 at 12:15 PM
    #117
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    4.10 and 4.30s only in the E-locker.
    808BOGEYMAN and Jase[QUOTED] like this.
  18. May 11, 2021 at 6:39 PM
    #118
    253-Tacoma
    253-Tacoma Member
    Tacoma, WA
    1996 Tacoma Base 2RZ-FE 2011 Tacoma SR5 2TR-FE 4x4
    Both De-Catted running URD 02 simulators
    3.58 base model on 14" steelies :D Does anyone know if plus sizing to maybe 225/75/15 would be too much? Would the 4AT take it even though I'd be one very slow taquito :rofl:
  19. Jun 5, 2021 at 6:55 AM
    #119
    Archaic2021
    Archaic2021 Well-Known Member
    2hat if there us just a question mark on the sticker?
  20. Feb 1, 2023 at 9:03 AM
    #120
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    2000 4runner here. Is this saying I have a 7.5" rear with 4.10s and two pinion open rear end?
