OEM grille changes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lightsped, Dec 24, 2014.
  1. Dec 24, 2014 at 11:07 PM
    Lightsped
    Lightsped [OP] Well-Known Member
    David
    Acworth/Kennesaw, Georgia
    Basic 2wd RC 5 speed
    Are there any differences between the 2005-2010 OEM grilles? I realize the 2011 had the egg crate texture on the inside of the grille, and that the 2012+ grille is completely different.
  2. Dec 24, 2014 at 11:12 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    iirc
    2005-2011 is the same
    2012-2015 is the same
  3. Dec 24, 2014 at 11:21 PM
    Lightsped
    David
    A coworker of mine has a black base RC 2wd just like my silver base RC 2wd. His is a 2011. Mine is a 2009. His has a slightly different grille. His has an egg crate texture on the inside parts of the grille areas. Both are trucks are 100% OEM.
    This coworker of mine mentioned that when the Tacoma received OEM LED tail llights (2009) that he thought the grille was changed slightly too. I hadn't heard this, but the Tacoma Wikipedia says the same thing about the 2009 getting a different grille compared to 2005-2008.
  4. Dec 25, 2014 at 2:21 AM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    What are you trying to do with the grille?
  5. Dec 25, 2014 at 2:37 AM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    There are all kinds of differences....05-11 all fit the same but come in many different trims...such as base grey plastic, chrome surround with black center bar, chrome surround with grey painted center bar, color matched with black center bar, color matched with grey painted center bar...
