OEM Headlight Differences
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The67beast, May 7, 2019.
  1. May 7, 2019 at 10:19 AM
    The67beast
    The67beast [OP] Active Member
    2009 Tacoma Reg Cab 4x4
    A question for you Toyota part number gurus. I am shipping headlights and just want to know the differences in the 04173 and the 04210. I think they are darker than the ones I have. I currently have the bright chrome 04200. Thanks!
  2. May 7, 2019 at 10:25 AM
    Muddinfun
    Muddinfun Well-Known Member
    Here's a quote from the ultimate headlight upgrade thread.
    OEM 2005-2011 smoked headlights:
    These are like the Pro lights, but came on select Sport models. These are available loaded with bulbs, and unloaded w/o bulbs, saving $60 off the set . These part numbers are for the unloaded housings. These are the updated TSB version of the lights that do not have the melting DRL issue.
    Right #81130-04173
    Left #81170-04173
    Norton likes this.
  3. May 7, 2019 at 10:45 AM
    The67beast
    Awesome! Thanks for the info!
    Muddinfun likes this.
  4. Jun 18, 2019 at 9:37 AM
    thruhike98
    thruhike98 Well-Known Member
    D.C. Metro Area, South of the Potomac
    2011 AC V6 4WD 6-Speed Manual Tow Pkg Silver TRD Sport
    Keeping it stock-ish: • Michelin Defender LTX M/S 265/65R17 • Removed TRD Sport Bedside Decals • Removed Westin Nerf Bars (Prev. Owner) • OEM Running Boards • OEM Bed Mat • OEM Cargo Net • Spare Tire Cable & Lock • Hose Clamp Tailgate Theft Deterrent • Front Door Windows Tinted • Gecko's Sliding Window Security Bar • ImMrYo's Rear View Mirror Mount • Undercover SE Tonneau Cover • Removed Driver's Seat Lumbar Adj. Knob • Denso Iridium Spark Plugs • Removed K&N Air Intake (Prev. Owner) • OEM Air Intake • FIXD OBD-II Monitor • Redline Gear Oil: Trans., T. Case, F. & R. Diffs. • OEM All-Weather Floor Mats • Brake Quiet to Stop Clicking on First Press • OEM Daytime Running Lights Relay & Jumper • Original OEM Non-D.R.L. Relay • Goplus Hitch Extender Rack • Smittybilt Receiver D-Ring, Recovery Strap, & Shackle • BOLT Receiver Lock • Mpow Phone Holder, CD-Mount • AUKEY CC-S1 2.4A Dual-Port Charger × 2 • Removed Faded "4x4" from Mud Flaps • AUKEY DR02 Dashboard Camera
    I just asked my local dealer which part numbers belong to the updated headlight assemblies (without bulbs); the ones you list above, or the ones I copied from the Toyota warranty extension PDF (POL 14-03). Based on my TRD Sport's VIN, my parts dept. contact person tells me:
    Part #'s 81110-04173 and 81150-04173 are the original part numbers.
    The updated part #'s are 81110-04210 and 81150-04210.
    Posting to let people know that, at best, there is some confusion as to the correct part numbers. Perhaps my local dealer is correct. Perhaps Muddinfun is correct.
    I think I'll go with my dealer and the Toyota warranty extension document (the -4210 part numbers). At least if the parts are wrong, it's their error.
  5. Jun 18, 2019 at 9:53 AM
    Muddinfun
    Interesting. I just quoted what @crashnburn80 posted in his ultimate headlight thread. The headlights are sold with or without bulbs. Let us know how it all plays out.
    crashnburn80 likes this.
  6. Jun 18, 2019 at 9:59 AM
    thruhike98
    Yes, I've read his posts. When I search all of these part numbers, they look legit. It's odd that it's so difficult to pin it down to one set of part numbers.
    Muddinfun[QUOTED] likes this.
  7. Jun 20, 2019 at 11:16 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I've done a bunch of searching since seeing this and find the data compelling. I will update the headlight thread accordingly. I wish it was easier to distinguish between all Toyota's part numbers for smoked vs chrome vs pre-TSB vs Post TSB vs loaded vs unloaded and all the combinations there of.
    thruhike98 and Muddinfun like this.
  8. Jun 21, 2019 at 1:23 AM
    Muddinfun
    It seems odd that they would even still sell the preTSB headlights.
    crashnburn80 and thruhike98 like this.
  9. Jun 21, 2019 at 6:20 AM
    thruhike98
    Good point!
