OEM hitch a bolt on?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ransom, Nov 15, 2013.
  1. Nov 15, 2013 at 3:43 AM
    Ransom
    Ransom [OP] Member
    Jeffery
    Ann Arbor MI
    stock
    My base Taco was never equipped with a hitch. I pretty much decided the Curt model everyone sells would be sufficient. I plan to do some light recreational pulling(pop-up and utility trailer).
    However I found a GenII OEM hitch(and bumper if I want it) on CL for $35.
    My questions are:
    Will the OEM hitch bolt on to my truck?(assuming I will need to get some high quality fasteners). Any hole creating in the frame required?
    Will I be able to mount it with my existing bumper or do I have to swap the donor bumper too?
    Is the OEM better/worse/same as the Curt?
    Thanks in advance for any help!
    Add to Ransom's Reputation Quick PM Report Post
  2. Nov 15, 2013 at 3:52 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You should be able to use that OEM one - There are some supports and a few extra bolts that you'll need to either buy w/ that hitch or get from somewhere else.
  3. Nov 15, 2013 at 6:15 AM
    Spruce Juice
    Spruce Juice Well-Known Member
    Sam
    Vancouver, BC
    2012 4 x 4
    Fold A Cover, Factory Class 4 Hitch with Factory Harness, Cruise, Int Wipers, TRD Alloys, Fogs, K&N Air Filter
    Buy the factory hitch. All the mounting holes are aligned with the truck bumper and frame so no drilling required. It is also totally hidden. I bought my used and had to order up a few pieces of hardware from the dealer…. inexpensive.
  4. Nov 15, 2013 at 6:21 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I have a Hidden Hitch and, for light duty towing, it works just fine but for $35, get the OEM one. It's a lot stronger than the aftermarket ones due to it being reinforced much better. You can use your bumper, it should bolt to receiver instead of the frame if my memory serves me correctly. Now, you have filler plates that attach your bumper to the frame, those will go away.
  5. Nov 15, 2013 at 6:29 AM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    Pretty sure the OEM hitch is a class 4. The truck can't tow 10,000 lbs nor does it have a 1000 tongue weight, but better to over engineer the part in my book.
    Curt is a great brand and the have nice designs, that also probably bolts right up with no drilling. But that OEM price is great for what you get, provided the hitch isn't rusted out or abused.
    Go for OEM for the price. If it doesn't pan out, Curt is an excellent option.
  6. Nov 15, 2013 at 7:53 AM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    I went to the local junkyard trying to pic up the oem hitch. Guy tried to tell me the hitch and bumper were once piece - wanted $700 for the stupid thing. F'in idiot!
  7. Nov 15, 2013 at 4:59 PM
    Ransom
    Ransom [OP] Member
    Jeffery
    Ann Arbor MI
    stock
    TY everyone for the input, for sure it was helpful!
    Yeah the price is right, even if I need to backwards engineer it and scrounge some parts. I like the fact OEM is less obvious as well.
    Trouble is, now the CL guy is playing hide and seek, so might not materialize.
  8. Nov 15, 2013 at 5:18 PM
    AdrenlineJunky
    AdrenlineJunky Active Member
    north
    013 2WD ACCESS 2.7 auto
    I just installed a curt on my 013 2.7 auto x-cab 2wd taco TODAY! Bolts right up with no sweat. I got mine with the wiring for $155 to my door. You do need a helper to install...its a two man job as the rear bumper comes off momentarily.
  9. Nov 15, 2013 at 6:06 PM
    pmbazus
    pmbazus Well-Known Member
    AZ
    2020 TRD Off Road
    I installed a Curt hitch on my 2012 4WD Reg Cab by my self. All bolt on. You don't have to take the bumper off. just loosen it.
  10. Nov 16, 2013 at 1:10 PM
    Spruce Juice
    Sam
    Vancouver, BC
    2012 4 x 4
    The side benefit of the OEM hitch is it will make your rear bumper much stronger because of how the hitch is attached to the frame and the bumper. You essentially discard the existing bumper mount brackets which are super lame.
  11. Nov 17, 2013 at 4:27 AM
    Ransom
    Ransom [OP] Member
    Jeffery
    Ann Arbor MI
    stock
    Seller called last night. Said he owns a tow yard and he took if off a late model destined for the crusher. He said its was easier to pull the entire bumper assembly than just the hitch(which is what you guys have been saying). He said bumper is chrome so I will have to swap my black cover if I don't want chrome. He said he only wants 35$ for the assembly. He's a few hours away so is sending me pix before I commit/head out. Sounds too good to pass up, though I have to include cost of gas and drive time in the equation as well.
    Thanks again for the feedback, I do appreciate it!
