oem hitch install questions
Discussion in 'Towing' started by othater, Apr 18, 2010.
  1. Apr 18, 2010 at 7:43 PM
    othater
    othater [OP] Well-Known Member
    SoCal-Walnut
    06 Prerunner SR5 TRD Sport
    I just installed a used oem hitch. A couple of questions.
    1) It did not come with the L-brackets. Can I use a piece of angle iron and drill some holes or buy two brackets from the dealer?
    2) It also did not come with the two bolts that attach the hitch to the bumper. I did a searched and the recommened #8 bolt standard or #10 metric. Should I buy a set from hardware store, Home depot OK or the dealer. What is the correct length?
    Thanks for the help ahead of time.
  2. Jul 2, 2011 at 11:01 PM
    jeckel7234
    jeckel7234 Well-Known Member
    Drew
    VA
    05 Tacoma
    Add-a-Leaf, Leveling Kit, 31.5 Nitto Grapplers, Mag-Lite Mod, Anit-Key in the ignition beep mod, Tail gate theft mod, Trifecta tonneau cover, washable cabin air filter,
    bump on the L bracket
  3. Jul 3, 2011 at 4:09 AM
    jeckel7234
    Drew
    VA
    05 Tacoma
