oem intake mods for 4.0
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lita4x4, Jul 27, 2016.
  1. Jul 27, 2016 at 2:22 PM
    Lita4x4
    Lita4x4 [OP] Well-Known Member
    Daniel
    California
    2017 DCLB TRD Sport
    Are there any mods that can be added or done to oem intake? Or just change out to an aftermarket one? For better flow,sound,power,mileage.
  2. Jul 27, 2016 at 2:38 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Aftermarket may have better flow and sound, but probably not better power and mileage. Stuff like this, and like exhaust, etc.. Is only really beneficial with a custom ECU tune.
    But... You can do he deck plate mod which is basically cutting a hole in the oem air box, and you really should direct cool air from the front on the vehicle to that hole as to not be sucking up hot air. And also maybe a cover for splashes.
    You can also remove he secondary air filter in the oem intake and buy a k&n drop in filter.
    Or just buy a full CAI system, as you don't want just a short open intake that sucks up hot engine air and possibly water/debris
  3. Jul 27, 2016 at 2:40 PM
    Sterling_vH111
    Sterling
    socal
    If doing the deck plate mod, but a large diameter threaded pvc pipe cap so you can close if off if need be.
    could also maybe buy a volant CAI air scoop to direct cool air to the air box.
