OEM Integrated rotary fog-light switch on column headlight switch/stalk
Discussion in '1st Gen. Tacomas (1995-2004)' started by digitalferg, Jan 21, 2017.
  1. Oct 18, 2023 at 10:30 AM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    Thank you sir. So your high beam light on your cluster lights up when you turn your fogs on? Is that just for preference?
  2. Oct 18, 2023 at 7:53 PM
    btu44
    btu44 Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    Yea, I used to have the 'fog light' switch on the center console. One time I forgot they were on when I got back on to the road. I was flashed a few times by oncoming traffic before I figured the fogs were on. The high beam indicator is a good reminder. The two diodes are to prevent voltage being feed into the daytime relay. I did not know if there would be a problem or not, so I installed the diodes to be safe.
    Nano909 likes this.
  3. Oct 18, 2023 at 8:12 PM
    Nano909
    Xcab 3.4 4wd 5MT
    Oh okay, I can probably bypass that step since I would notice the fog lights on.
    btu44[QUOTED] likes this.
  4. Dec 12, 2023 at 2:25 PM
    Nano909
    Xcab 3.4 4wd 5MT
    Thanks to you, I was able to get it done! I just used the harness that came with my fog lights and everything is working flawlessly. Looks OEM for sure.
