OEM inverter wiring harness in Non TRD models??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dessertsand05, Jul 4, 2013.
  1. Jul 4, 2013 at 3:31 PM
    dessertsand05
    dessertsand05 [OP] Well-Known Member
    Boston
    05 Tacoma DC SR5 4x4
    Working on it
    Grabbed an OEM inverter a while ago and never got a chance to hook it up. Trying to clean out the garage and finish some projects. I dont need an outloet in the bed, just looking to add some outlets for the back seat.
    Anyone know if an 2005 SR5 DCLB would have the wiring harness needed to install a stock inverter?
    I have the inverter and brackets, is all I would need be the switch and inverter?
    I know there are much better inverters out there. I just want to use it to power some electronics in the back seat, and want it to look stock.
    I did a search, but nothing mentioned if the wiring harnesses are present in non trd models.
    Appreciate if anyone had any info or has noticed when they took their dash apart.....
  2. Jul 5, 2013 at 7:17 AM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    My 08 Prerunner is SR5, I have the wiring harness/connector in the dash for the OEM inverter. The plug is connected to one of the blank switch covers on the left side of the dash. I haven't checked to see where the other end of the wiring comes out as I haven't tried to hook this up yet.
  3. Jul 5, 2013 at 7:19 AM
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    Sub'd interested in the answer also.
  4. Jul 5, 2013 at 7:45 AM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Wouldn't know, but I have the trd inverter. By now I'm sure you know it's under the center box/arm rest.
    The box comes off easily, there are two cables/connectors there, and not much else. If you are wired for it, it should be really obvious.
    I've actually bought a 1500 watt to replace it, and will likely have to upgrade the feed wire.
    Btw. You want it to be OEM looking but on my truck there is only the bed socket. I'm going to add USB and 110 sockets to the back of my arm rest. Easily done with the replacement inverter but would require some splicing on the OEM inverter.
  5. Jul 24, 2013 at 7:28 AM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    there's a plug underneath the center console that i think would connect to the oem inverter, i have an SR5 also and have done some digging on this topic
  6. Dec 6, 2013 at 10:15 PM
    sernaj64
    sernaj64 Aight
    Juan
    honolulu
    2011 prerunner V6 SR5
    N fab Step bars BHLM by Asianants Pro Comp 2.25" level lift kit rear leaf TSB
    sub wana do this
