OEM Ipod adapter vs aftermarket
Discussion in 'Audio & Video' started by Squid, Mar 4, 2010.
  1. Mar 4, 2010 at 2:38 PM
    Squid
    Squid [OP] Swollen Member
    Dave
    Houston, Texas
    2010 Barcelona Red PreRunner TRD Off Road
    Debadged, Factory Roof Rack, Black Nerf Bars, Black MB Chaos Wheels, 265-75-16 BFG All Terrain T/A KOs, Rear Leaf TSB, Body Colored Grill with center sprayed black
    Hi. I'm about to pull the trigger and buy a 2010 Tacoma. My question is, is it worth it to get the factory Toyota Ipod adapter, and does it show text on the factory radio? If not, do any of the aftermarket adapters show text and allow you to control the Ipod from the steroa just like the factory one?
    Basically, I'd like to know whether I should get this option or wait and get an aftermarket one that performs the same or better.
    Any suggestions?
    Thanks!
  2. Mar 4, 2010 at 2:44 PM
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    aftermarket is def the way to go. better sound quality, better output.most have ipod compatible cords that plug either into the front or the back(can be routed to glovebox) and they arent much more than say a 230 dollar toyota ipod adapter or a 120 dollar PA-15 toy
  3. Mar 4, 2010 at 2:52 PM
    Squid
    Dave
    Houston, Texas
    I think you ae referring to an aftermarket stereo. I don't want to go that route at the moment. I like the factory look and would like to keep the indash 6 disc changer. Later, I will use a loc to add an amp and speakers and a small sub, but that's as far as I want to go.
  4. Mar 5, 2010 at 5:14 AM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    OEM one SUCKS!!!!!!!!!!!!! I have it and you can't do much with it. At least with the iPod I was using. you don't get the text, can't even change the song to another with the radio, the volume isn't good either (can't adjust from iPod, so the iPod volume doesn't matter).
  5. Mar 5, 2010 at 6:42 AM
    Squid
    Dave
    Houston, Texas
    Thanks! This helps a lot. I will definitely stay away from the OEM one.
  6. Mar 5, 2010 at 6:49 AM
    07TacoRidah
    this ones tight cause it lets you have full control of the iPod with your stock radio. So no more having to pick up the iPod or have it somewhere around for you to push the track buttons, also the volume is like it should be, not all oddly low for some reason esp. even when you have it all the way to 60 on the stock radio.
    http://www.gromaudio.com/store/ipod_adapters/grom-i2-toy.html
  7. Mar 5, 2010 at 7:07 AM
    ummgood
    ummgood Well-Known Member
    Austin, TX
    05 4x4 DoubleCab SR5
    I have the GROM and I love it. I swear the sound is better from the iPod than the internal CD player. I haven't figured out how to display text from the iPod even though they claim you can. I have my iPod Touch mounted using a cup holder mount so I can see it easily and no need for the text display. All the steering wheel controls work.
  8. Mar 5, 2010 at 10:27 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    Some food for thought.....
    If you're adding an Ipod to your setup, will you really be using the 6-Disc changer? :rolleyes:
    Since adding an Ipod to my HU, I have not played 1 CD. Might just be me though. :cool:
    For the cost of most factory HU Ipod adapters you can get a decent aftermarket HU and really have something nice.
  9. Mar 5, 2010 at 10:52 AM
    07TacoRidah
    true, there is an abundant amount of aftermarket h.u.'s with usb connection and iPod connectors also. Plus they are fully integrative to the iPod, meaning that you will be able to control them, volume is how it should be, charge them, etc. with the h.u. If you want to add in amps, check the backs of them though. Some only have one set of RCA outputs.
