OEM LCA Cam Bolts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by essjay, Feb 13, 2025.
  1. Feb 13, 2025 at 9:59 AM
    essjay
    essjay [OP] Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    I'm planning swapping out my LCAs for new ones in a few weeks, and it was recommended to me to buy new OEM cam bolt assemblies. However, poking around on ToyotaPartsDeal, I'm only seeing the varioius parts being sold piecemeal (https://www.toyotapartsdeal.com/oem-toyota-alignment_bolt.html)? Is there anyway to buy the entire assembly as a kit, without going aftermarket? And if I do need to go aftermarket, which brand is the best option?
  2. Feb 13, 2025 at 10:00 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
  3. Feb 13, 2025 at 10:45 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    You really only need new ones if the current ones are corroded/damaged. With truck on level ground try and remove each cam bolt to see that it is not seized. It is usually the front facing cams that seize. One of mine did. I replaced with a cheap aftermarket from Amazon. Coated the cam bolts with grease to avoid further corrosion issues. My other three remain oem.
  4. Feb 13, 2025 at 12:09 PM
    TacoTuesday1
    SD CA
    I re-used mine. Prepped the job with regular stuff like heat, aerokroil soak, etc.
    OEM is expensive
    I've seen someone try to replace theirs with aftermarket and they didn't seem good. Very sloppy loose fit.
    fatfurious2 likes this.
  5. Feb 13, 2025 at 12:15 PM
    essjay
    Concord, CA
    Yeah, that's why I'm trying to avoid aftermarket. I figure I can buy in advance and then return or flip any I don't need.
  6. Feb 13, 2025 at 1:15 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    My recommendation would be to mark the locations of your current bolts, loosen them one by one and see if you can turn/adjust them. If you can, great. Move them back to where they were and re-tighten until you're ready to change them out.
    IF you can't move them, they are seized and you'll need new hardware.
    In my opinion (and I have no problem with some aftermarket stuff), this is one area where I'd stay OEM.
    Which ever route you go, put some grease or something on the new ones when you install them to keep the from seizing again. Recheck your torque on them every week or so for a few months afterward.
  7. Feb 13, 2025 at 2:30 PM
    Chuy
    Lakeside, CA
    Silver Taco
    The front facing ones slide into a sleeve, which is where they seize. The LCA will not move if you are on level ground when you loosen the bolt and try and slide it out. I wouldn't even bother loosening the rear ones.
  8. Feb 13, 2025 at 2:36 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Up here they're always seized, and they immediately flatten the tabs on the frame as soon as you try to turn them with a wrench
    I wouldn't even start the job without having everything on hand ready to go if needed..
    4WDTrout, fatfurious2 and TnShooter like this.
  9. Feb 13, 2025 at 4:03 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Unfortunately, you cannot get them in bulk, As a complete assembly, you have to get all separate different part numbers. Do not go after market, always go with OEM but this time when you go with it, you want to put as much antiseize that will be accepted within the assembly.
  10. Feb 14, 2025 at 6:41 AM
    HWI
    HWI Well-Known Member
    North Florida
    2015 Tacoma TRD Off Road
    I am surprised anyone can reuse them, even down here in Florida they seize to the sleeve. I switched to the greaseable Moog cam bolts, so I hopefully don't have to worry about that the next time I have to take my LCAs off.
