OEM Led foglight bulb change?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by midniteben, Feb 17, 2023.
  1. Feb 17, 2023 at 11:49 PM
    midniteben
    midniteben [OP] Member
    Glendale CA.
    2019 TRD OR
    Hey my '22 came with the optional 'led headlights/foglights'. Can you change the foglight bulbs to amber?
  2. Feb 18, 2023 at 6:03 AM
    Bronxguy
    Bronxguy Well-Known Member
    Frank
    New York
    2021 Off Road
    No you can't, but if you want there is a a film that is placed over lens, Lamin-x t554th fog light cover on Amazon, you can give it a go, cheap enough, cheers
    RIX TUX likes this.
  3. Feb 18, 2023 at 6:23 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I have the Laminex amber films on my stock fogs. Been on there almost 2 years and still look great. Some minor "bubbling around the edges but you have to get up pretty close to notice it.
  4. Feb 18, 2023 at 8:55 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    OEM halogens can be changed out easily. Got a set going up on marketplace later today.
  5. Feb 18, 2023 at 9:02 AM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    So you have the LED Headlights, I got that...but the LED Foglights too?
    Can you post pics of your setup?
    Reason I ask, I bought/installed LED Headlights and then changed out the H16 bulbs to Diodes for the Foglights--they're white of course.
    I don't see why you couldn't change them to yellow diodes...or any other type of LED foglight.
    All depends on how much you wanna spend.
    TRDRed likes this.
  6. Feb 18, 2023 at 11:32 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    As others have said, laminx on the lens works great
    DBF and TRDRed like this.
  7. Feb 18, 2023 at 1:43 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    its not a bulb, its an led
    TRDRed likes this.
  8. Feb 18, 2023 at 3:32 PM
    DBF
    DBF Well-Known Member
    2012 Tacoma, 4x4.base model, access cab.
    Is there a benefit with having amber colored fog lights??
  9. Feb 18, 2023 at 4:05 PM
    InThePlains
    InThePlains Well-Known Member
    Absolutely.
    Longer wave length of the yellow light is the key factor of cutting through "fog".
    Applying Lamin-X film on 3rd gen fogs are super easy, by removing the light assembly, only a single screw holding it.
    DBF[QUOTED] likes this.
