Oem led fogs?
Discussion in 'Lighting' started by Sirpopeington, Apr 6, 2019.
  1. Apr 6, 2019 at 1:37 AM
    Sirpopeington
    Sirpopeington [OP] Well-Known Member
    17' TRD Off-road 4x4
    I was about to order a set of Morimoto LED fogs and I came across these. I didn’t know there were oem led housings for tacos. Are these legit? If they are could they be decent quality?
  2. Apr 6, 2019 at 1:45 AM
    RockHed
    RockHed TTC #051
    Danny
    San Antonio TX
    2016 Black TRD Sport OnRoad 4x2
    Yes they are. Got the exact ones a couple weeks ago and are very happy with them. Got them while ebay had a 10% discount going on. The light output and cutoff is great!20190317_075501.jpg 20190317_075514.jpg 20190318_040307.jpg 20190319_035735.jpg 20190319_035725.jpg 20190319_041647.jpg
  3. Apr 6, 2019 at 1:46 AM
    RockHed
    RockHed TTC #051
    Danny
    San Antonio TX
    Sorry the pics aren't the best. Install was maybe 20 minutes
  4. Apr 6, 2019 at 1:28 PM
    Sirpopeington
    Honestly, for the cash I may just go this route rather than spend the extra 50+ on Morimotos. Thanks for the input man.
    BillsSR5 likes this.
  5. Apr 6, 2019 at 3:08 PM
    RockHed
    RockHed TTC #051
    Danny
    San Antonio TX
    No problem man, I looked at the morimotos for a long time just never pulled the trigger. Then I saw these which I believe are the exact ones that will be on the 2020 Tacoma. And with the EBay discount I couldn't pass it up. Good luck bud, you won't be disappointed
    AxisCab likes this.
  6. Apr 6, 2019 at 3:10 PM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    I paid right around $125 for my morimotos brand new.
  7. Apr 6, 2019 at 6:15 PM
    Tiny's Taco
    Tiny's Taco The Wanderer
    Shenandoah Valley
    2018 Inferno TRD Sport
    That's a horrible idea. What time?
    I have the Morimoto's. I'm not as impressed as I'd like to be for the money.
  8. Apr 8, 2019 at 12:32 AM
    bs63366
    bs63366 Well-Known Member
    San Angelo
    2014 Tacoma TRD Off Road DCSB
    ARE Z-series shell, ImMrYo mirror lift, always on fog-lights.
    Just out of curiosity are these lights DOT approved on the lense? Unfortunately Hawaii checks on such things during safety inspections.
  9. Apr 8, 2019 at 12:52 AM
    RockHed
    RockHed TTC #051
    Danny
    San Antonio TX
    I would think the Toyota OEM LEDs should be since they already use these on some of their vehicles, and these are the ones going on the 2020 Tacoma's. As far as the Morimotos I'm not sure, but this is in their descritption, " The Morimoto fog lamps meet and exceed all SAE, DOT, and ECE regulations". Hope that helps a bit.
  10. Apr 8, 2019 at 3:04 AM
    Tiny's Taco
    Shenandoah Valley
    I don't recall if the lenses are marked or not, but they are identical to the OEM housing. If they are marked, it may be hidden behind the cover anyway. Would they check if it looks OEM?
    bs63366 likes this.
  11. Apr 8, 2019 at 6:20 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    07 Lexus GX470
    They are. They are Valeo and have SAE stamped on the front.
    bs63366[QUOTED] likes this.
  12. Apr 8, 2019 at 5:04 PM
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    LED factory fogs = like
  13. Apr 8, 2019 at 5:21 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    Questions on these have come up enough that I will add them to the LED fog thread. Should have an update for how they compare this weekend.
  14. Apr 9, 2019 at 6:17 AM
    Barnburner
    Barnburner Well-Known Member
    2015 Tacoma SR
    if you wanted yellow fogs, is your only option laminex across the lens? or can these be disassembled to apply the laminex on the internal lens?
  15. Apr 9, 2019 at 5:44 PM
    RockHed
    RockHed TTC #051
    Danny
    San Antonio TX
    Morimoto just came out with some amber LEDs, but looks like their all out. The only option is to put yellow Laminx film across the housing itself. Don't believe there is a way to take it apart.
  16. Apr 9, 2019 at 5:49 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    If you want selective yellow, the best option is the Rigid SAE selective yellow fogs, they will be available this month.
    https://www.rigidindustries.com/sae-dot-compliant-selective-yellow
    You can see I tested the prototypes back in October:
    https://www.tacomaworld.com/threads...fog-light-review.554813/page-14#post-18889711
    The final versions will be a bit more yellow using a warmer color temp LED than the prototype. I'll have the test results posted as soon as I receive the finalized version.
  17. Apr 19, 2019 at 7:02 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    olivaresanthony and RockHed like this.
