OEM LED Headlight Conversion Harness
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by daveeasa, Apr 30, 2021.
  1. Nov 28, 2021 at 5:34 AM
    #201
    daveeasa
    daveeasa [OP] FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I’m sure it can be repaired as well. Might just be a bad crimp somewhere. I run those as well and love them. The wires aren’t special it’s the bulbs which make it awesome.
    AppleIsSkynet[QUOTED] likes this.
  2. Nov 28, 2021 at 2:01 PM
    #202
    AppleIsSkynet
    AppleIsSkynet Well-Known Member
    Michael
    Warner Robins, GA
    2021 Tacoma TRD Off Road
    OEM black exhaust tip Bullet Proof Designs phone mount
    When ever he contacts me I’m hoping it can be fixed or replaced as they’re now out of stock everywhere.
  3. Nov 29, 2021 at 9:26 AM
    #203
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Hey @daveeasa I’m on the verge of ordering the OEM LEDs but was curious about your harness. I’ve got the V5s and the harness for those to hook up the my current DRL, installed.
    I think I asked this one the other thread but can’t seem to find it, would I be able to hook that into your base harness or would I need to order the one from you, with the added v5 hookup? Thanks!
  4. Nov 29, 2021 at 9:28 AM
    #204
    daveeasa
    David
    PNW
    Both will work. The DRL T tap for v5's (both MESO's one and R4T's for grille lights) simply goes upstream of the conversion harness. The more expensive integrated option just reduces bulk and extra connectors (only one female DRL connector vs two females and a male) in the event of OCD.
  5. Nov 29, 2021 at 9:38 AM
    #205
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Thanks for that! I definitely do not have OCD… though I do like things to look nice.
  6. Nov 29, 2021 at 9:42 AM
    #206
    daveeasa
    David
    PNW
    Totally your call on the aesthetics vs cost. Functionally there should be absolutely no difference. With that said, LOE on the install if you already ran through the firewall is pretty low.
    hyrule_trd[QUOTED] likes this.
  7. Nov 29, 2021 at 9:54 AM
    #207
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Good to know. Yeah, I’ve got the V5s hooked up and working. They even dim when the headlights come on, which I was not expecting to work without having to wire it to the ECU.
  8. Nov 30, 2021 at 12:35 PM
    #208
    MGMDesertTaco
    Edit: Nevermind, brain fart. :oops:
    @daveeasa
    I'm confused here.
    Also looking at V5's to go with my LED Headlights and your harness. Meso claims their V5 harness will only work with factory halogen headlights and they're working on something for LED headlights. What would I need (I have your standard harness, no grill lights) to connect the red and white wires on the V5's for the drl's?
    2:23 mark...
    https://www.youtube.com/watch?v=_tJBFRkSSfY
  9. Nov 30, 2021 at 12:44 PM
    #209
    daveeasa
    David
    PNW
    This is the same language R4T uses with the DRL grille light harness. It's "misleading" (and I don't say that to disparage R4T or MESO who I think are top shelf in all aspects.) What is meant by that is "Did your Tacoma come from the factory with LED headlights" vs "Did your Tacoma come from the factory with halogen headlights" rather than "does your truck currently have LED or halogen headlights". Trucks which came factory equipped with halogen headlights can do 100% of things that trucks currently running halogen headlights can do because you have all the connectors. Trucks which came from the factory with LED headlights are only able to accept MX-150 connectors to steal stuff like DRL. I make an LED T tap for this purpose, MESO may offer something in the future which will look a lot like the halogen T tape he has available now.
    Does that help explain things?
    Bottom line, you can trust me on this stuff, I won't steer you off a cliff.
  10. Nov 30, 2021 at 12:48 PM
    #210
    daveeasa
    David
    PNW
    Oh, and sorry, forgot to actually answer the "What would I need" question.
    You can get MESO's $15 T tap. Or a halogen T tap from me if you really want it. Or an integrated headlight harness with T tap (but that's now redundant conversion harnesses so kind of a bummer for you). Or hack and slash the conversion harness you have to steal DRL and a tap from the sidemarker for parking light. Kind of "too many" options really rather than too few.
    The only reason you might not opt for the $15 MESO DRL T tap is that extra bulk/length between it and the conversion harness and your headlights, makes for a bit of a rats nest. That's by far your cheapest route.
  11. Nov 30, 2021 at 12:51 PM
    #211
    MGMDesertTaco
    Thanks, I was just reading over the form for your headlight t- harness. I guess I need to make up my mind if I want the grill lights now too with the V5's. Also, I'm assuming the switch pros option will work with any 6-8 panel switch? I was looking at this cheaper one from auxbeam.
    https://auxbeam.com/products/qp0025...MI-LnZk_vA9AIVF2pvBB3uiA5JEAQYAiABEgKzGvD_BwE
  12. Nov 30, 2021 at 12:57 PM
    #212
    daveeasa
    David
    PNW
    The "switch-pro" stuff is just trigger wires. I don't know auxbeam at all so it's up to you to decide what you need?
    * The red cable connects the master switch power cable to the ACC.If you want to light up the LED lamps before the car start-up, please connect the recommended because the higher the power is, the more the power of the battery will be consumed.
    * The yellow cable connects the width lamp to the master switch panel.
    * The white cable is the panel light brightness control cable. It can controls 3 brightness levels by each switching. You can disconnect the white cable in order to have the most brightness switch panel if required.
    I'm guessing that the parking light can be used to feed the white wire? If so then it's a matter of where that connection is made, if it's in the cab you can get a switch illumination harness, but if it's in the engine bay you can always steal that from the sidemarker even if you don't have it off the headlight conversion harness, so plenty of options.
    I don't see mention of an aux trigger wire like the pink on Switch-Pros which people frequently feed from high beams. That's the primary reason to really want/need the headlight conversion harness signals. Some guys have asked for DRL as an aux trigger but I'm not so sure that really makes a ton of sense to me vs high beam, not a ton of value unless you've got a christmas tree worth of drl's.
    MGMDesertTaco and hyrule_trd like this.
  13. Dec 2, 2021 at 1:42 PM
    #213
    eclane
    eclane Well-Known Member
    2020 Black TRD OR DCSB
    Thanks for including extra clips. I needed a blue one after separating the fender! Your harness is top notch.:thumbsup:
    daveeasa[OP] likes this.
  14. Dec 10, 2021 at 12:21 PM
    #214
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    I’ll put my order in once I know my set has shipped!
  15. Dec 13, 2021 at 3:33 PM
    #215
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
  16. Dec 13, 2021 at 3:35 PM
    #216
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    Thanks.
    AY_ARONTRD[QUOTED] likes this.
  17. Dec 13, 2021 at 3:36 PM
    #217
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    Just double check with Dave your putting the right order in.
  18. Dec 13, 2021 at 3:37 PM
    #218
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    I just PM'd him. I'll wait to hear back.
  19. Dec 13, 2021 at 4:41 PM
    #219
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    I'm sorry if this has been answered.. what bulbs do I need to make this work? I have a 19 off road premium/tech. And this is for high/low and running lights?
  20. Dec 13, 2021 at 4:50 PM
    #220
    daveeasa
    David
    PNW
    This is for swapping the entire assembly to Toyota’s LED headlights for 3rd gen Tacoma. Bulb swaps do not use this harness.
    supmet likes this.
