OEM LED Headlight Conversion Harness
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by daveeasa, Apr 30, 2021.
  1. Oct 18, 2021 at 12:05 PM
    #161
    caribe makaira
    Caribbean, Puerto Rico
    DES2009 likes this.
  2. Oct 19, 2021 at 1:10 PM
    #162
    Ran-TRD
    Ran-TRD Well-Known Member
    My apologies for the delayed response. Ok this makes sense so I can bypass connections if I don’t have those lights quite yet. Will place order tonight ! Thank you for the clarification!
    daveeasa[QUOTED][OP] likes this.
  3. Oct 30, 2021 at 7:54 PM
    #163
    TacoGuySlo10
    TacoGuySlo10 Well-Known Member
    Tristan Torres
    san luis obispo
    2019 MGM trd off road
    are you still making these? i’ll order a set if you are!
    daveeasa[OP] likes this.
  4. Oct 30, 2021 at 10:37 PM
    #164
    daveeasa
    daveeasa [OP] FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Lots of stock on hand and actively making more. Just got a resupply on parts. I’ll post if I run empty and anticipate any delays but right now these are shipping promptly.
    brenclarktrd, billas taco and FishnTx like this.
  5. Nov 5, 2021 at 12:14 PM
    #165
    ScootARoot
    ScootARoot Where's my keys
    TJ
    Georgia
    '21 DCSB OR Black
    Guys, please don't roast me. Just want to make sure I don't order something I don't need before I purchase.... again.. (not from here btw)
    I have 2021 TRD Off Road with halogens and the LED driving lights (all stock light setup). This harness will let me upgrade to the OEM LEDs, correct?
  6. Nov 5, 2021 at 12:15 PM
    #166
    caribe makaira
  7. Nov 6, 2021 at 12:05 PM
    #167
    TRDSport17North
    TRDSport17North 06SR5,17TRDSport,22TRDSport
    Al
    Ontario Canada
    22 TRD Sport D/C L/B Premium
    Oem LEDs Heads and Fogs, Interior and exterior LED's, Tonneau Cover, Tint, Running Boards, decals overlays and inserts, Bed mat and lighting, Mats, Speaker upgrade, amp, powered sub, Dsp. Meso Stage 1 tails. Complete front end Expel paint protection, ceramic coated, rust protection, 265 70 17 Cooper at3 4s on 17" OEM Sema Pro wheels. More to come...
    Hey Dave thought I'd do a dry fit harness wise with my 17 before my 22 comes next month. I followed your quote above and have this one open end connector not in use with no cap. Is this for maybe the raptor lights, or am I missing something. I have DRL on the 17 and will on the 22. Scratching my head here. Thanks Al
  8. Nov 6, 2021 at 12:23 PM
    #168
    daveeasa
    David
    PNW
    That is the DRL connector. It’s female on the conversion harness.
  9. Nov 6, 2021 at 12:29 PM
    #169
    caribe makaira
  10. Nov 6, 2021 at 12:29 PM
    #170
    TRDSport17North
    Al
    Ontario Canada
    So it's not needed here?
  11. Nov 6, 2021 at 12:30 PM
    #171
    daveeasa
    David
    PNW
    You need it. If your truck is a sport and has the L shaped DRL board, the headlights would have a female connector. Find it and unplug and attach to conversion harness. It’s a pigtail off the headlight vs a snap in bulb.
  12. Nov 6, 2021 at 12:31 PM
    #172
    daveeasa
    David
    PNW
    You probably just didn’t see it
  13. Nov 6, 2021 at 12:31 PM
    #173
    caribe makaira
    Or the picture I posted either.:rofl:
    musicisevil and daveeasa[OP] like this.
  14. Nov 6, 2021 at 12:35 PM
    #174
    TRDSport17North
    Al
    Ontario Canada
    Doh!! Found it, it's attached to some stand alone bracket. Thank Dave. Here goes
  15. Nov 6, 2021 at 2:19 PM
    #175
    TacoGuySlo10
    Tristan Torres
    san luis obispo
    Is there only supposed to be 1 little metal clip in these? or
  16. Nov 6, 2021 at 2:28 PM
    #176
    daveeasa
    David
    PNW
    Yes.
    The TRS harness bundles all grounds together. So if any is backwards you blow a fuse.
    I prefer using a single ground so it works or it doesn’t and no blown fuses. If you have the low beams reversed it’s just always low beam off. Swap and it’ll work properly. Safer in my book.
  17. Nov 6, 2021 at 2:29 PM
    #177
    daveeasa
    David
    PNW
    The technical word for the metal thingy is terminal and in this case male terminal aka pin. Female terminals are also called sockets. Cliff Claven approves this message.
    Shawny5ive likes this.
  18. Nov 6, 2021 at 2:30 PM
    #178
    TacoGuySlo10
    Tristan Torres
    san luis obispo
    haha okay just making sure before i start the install! thanks dave!
  19. Nov 6, 2021 at 2:31 PM
    #179
    daveeasa
    David
    PNW
    Color match all wires with one exception. Low beams are white with color matched stripe to solid color on OEM side. I do it that way because otherwise there are two blue wires on the passenger side and a greater chance of me making a mistake building them. It also offers some symmetry with the low beams so you know them from high beam in addition to the 1 wire vs 2.
  20. Nov 7, 2021 at 7:15 AM
    #180
    TRDSport17North
    Al
    Ontario Canada
    Question for you Dave.... Do you make a version of the stage 1 Mesa taillight kit or know of anyone that does? Seems Mesa have been out of stock forever on these kits. Thanks Al
