OEM LED Tail Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LATACOMAGUY, May 23, 2011.
  1. May 23, 2011 at 9:20 AM
    LATACOMAGUY
    LATACOMAGUY [OP] Active Member
    Marc
    Encino, CA (SoCal)
    08 Prerunner D-Cab SR5 TRD Sport
    Hi all, I am new to this forum. I've had my 08 Tacoma Double cab for about a year now and just recently decided to join this forum.
    I decided to upgrade my tail lights to the OEM led lights. I bought some off ebay that came off a 2011. But, in checking out the LED tail lights, I noticed that the plug for brake light only, has a adapter plugged into the socket where the bulb would go, and the adapter is connected to what appears to be a LED light board. Don't know if I am describing this correctly and not familiar with these at all. Is this correct for the new LED's, that the actually brake light section does not require a single bulb?
    Thanks.
  2. May 23, 2011 at 9:22 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Yup
  3. May 23, 2011 at 9:23 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Your fine. Its all plug n play. I have an 06' and put on 2010 OEM LED tails and they work perfect.
  4. May 23, 2011 at 12:13 PM
    LATACOMAGUY
    Marc
    Encino, CA (SoCal)
    Thanks all. I appreciate the quick response.
  5. Dec 22, 2011 at 8:25 AM
    g34rh34d
    g34rh34d Well-Known Member
    Colorado
    '08 4 DR TRD Off Road - ICON Stg 1 Adjustable Coil Overs ~3" lift, UCWMS, Airbags
    UCWMS; ICON Stg 1 Adjustable Coil Overs ~3" lift/shocks; Diff drop Spacers; Light Racing UCAs, Firestone Airbags
    Sorry to re-open an older thread, but yesterday I had a little boo boo on my Taco, and the drivers side tail light got cracked..DAMMIT! (not my fault btw.) ;-) I was checking the forum to see if anyone had a replacement drivers side tail light for sale for an 08, and I stumbled across this thread, and realized they upgraded the tail lights from incandescent bulbs to LED, so I figured WHAT THE HECK! Time for an upgrade!
    That being said, is it my understanding (based upon the comments in the thread above) that the 09+ tail lights are LED, and would be Plug and Play with the 08 Harness? I found a set on Ebay for $155.00, so before I jump on them I thought I better check with the experts!
    Let me know.
    Thanks!
