OEM lift kit questions
Discussion in 'ToyTec Lifts' started by hakan, Jan 25, 2011.
  1. Jan 25, 2011 at 7:39 PM
    hakan
    hakan [OP] Active Member
    hakan
    SF
    2002 toyota tacoma 4x4 TRD Off Road 3.4
    trail gear weld on rock sliders, leer camper, OME 883front Dacar springs in back, grey wire mod, rear diff breather mode, maglight mode, deck plate mode, camper shell defrost mode, UWS tool box,( viv air inboard air is coming soon)
    I just bought an Ome coil overs with 883 springs and full dacar 7 leaf spring pact.
    my front sit about 1.25'' higher than rear which I think will settle more given time, but the rear springs
    left side is way higher than right side I only have a camper shell and it seems like I have a negative arch already in the top spring.
    does anyone alse running this set up
    \I have a 2002 toyota Tacoma 4x4 trd offroad
    is your vehicle level?
    do you have an issue with negative arch with your leafs? does anyone have pictures of there springs with a camper shell on?
    I contacted toy tect and they said to give a little bit more time but the person i spoke to didn't make me feel like he had the answers.
    I hope to hear from you guys.
    Also the vibrations everyone talks about it that a faint vibration or a very bad one anyone?
    P.S i had the kit installed by a custom fabrication shop which does SAS convertions and super custom lift kits.
  2. Jan 26, 2011 at 9:50 AM
    ToyTec Lifts
    ToyTec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    PM replied
    :thumbsup:
