OEM Looking Garage Door Button/Opener Hack...
Discussion in 'Technical Chat' started by xjoey dubsx, Sep 23, 2015.
  1. Sep 1, 2022 at 3:24 PM
    #61
    traubgator
    traubgator New Member
    I know this is an old thread but I'm in the process of doing this mod (waiting on switch to be delivered).
    If i don't plan to light up the switch at all, which 2 wires from the green harness do i connect to the 2 wires from the garage remote.
    green and black
    or green and red 1...
    and to clarify -- I plan to power the "remote' using the DL2032 battery it came with vs powering the remote off the truck.
    and if i don't want the switch to light up to i need to ground the wire???
  2. Sep 1, 2022 at 5:11 PM
    #62
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    That’s what I did. Check my build thread. Ground is for switch illumination only. I think ch4x4 and AOB may use different colors on their pigtails.
  3. Sep 1, 2022 at 6:28 PM
    #63
    traubgator
    Thanks! Saw it in the screen shot from the build thread! I’ll give it a try hopefully tomorow.
    but if I decide to illuminate the switch, then I should use the ground?
  4. Sep 1, 2022 at 6:29 PM
    #64
    daveeasa
    David
    PNW
    Yep. Ideally PWM dimmer. @kmorgan3 can supply a T for that.
    traubgator[QUOTED] likes this.
  5. Sep 4, 2022 at 1:16 PM
    #65
    traubgator
    Worked like a champ.
    From a standard Toyota switch from ch4x4
    I connected green and red 1 to the garage door opener.
    then decided I needed illumination because the 2015 Tacoma lower center dash is so dark.
    grounded black to the truck and used a fuse tap for red 2.
    works perfectly!
    question - how many switches do you think the fuse tap can handle for illumination?
    I tapped into the 10 amp taillight fuse, and have 2 switched connected to that tap for illumination.
  6. Sep 4, 2022 at 1:24 PM
    #66
    daveeasa
    David
    PNW
    Probably a few hundred?
    Tacospike and traubgator[QUOTED] like this.
