OEM Lug Nut Sleeve separation issue
Discussion in 'Wheels & Tires' started by CQB 1911, Oct 22, 2011.
  1. Oct 22, 2011 at 3:17 PM
    CQB 1911
    CQB 1911 [OP] Well-Known Member
    Jesse
    AZ.
    2010 TRD OR AC
    I have an 2010 off road I bought last month. It has 13k miles on it now and it has the OEM wheels. I rotated my tires today. I noticed that a couple of the lug nuts tightened down on the studs fine but I can feel a little play between what seems to be a chrome "sleeve" on the lugs and the lug it self.
    Is this common and will this cause any issues now or down the road?
  2. Oct 22, 2011 at 3:22 PM
    Chainsmoker
    Chainsmoker Well-Known Member
    Ed
    Phila.PA
    09 Tacoma 4x4 double cab Short Bed
    3inch ProComp Lift. 285/70/17 on ATX Crawl wheels. tinted windows. blacked out tail lights. 8k hid fogs. projector headlights with dual halo rings and 8k hid. remote start. blacked out grille.
    This is common. Usually on older Lugs tho. once the sleeve comes off the lug is just the next smaller size. if you try to use the factory wrench you will strip the lugs.
  3. Oct 22, 2011 at 3:24 PM
    Chainsmoker
    Ed
    Phila.PA
    I would just go get some new ones. they are cheep. just don't get the same style with that stupid sleeve.
  4. Oct 22, 2011 at 3:43 PM
    CQB 1911
    Jesse
    AZ.
    2010 TRD OR AC
    Cool - Thanks
    Would you happen to know the specs for the lugs?
  5. Oct 22, 2011 at 3:50 PM
    Chainsmoker
    Ed
    Phila.PA
    No. I dont sorry. just head over to an auto parts store, they should be able to tell you. Oh and aluminum and steel wheels use different style lugs. just take one of yours off to match.
  6. Oct 22, 2011 at 3:52 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Thread and pitch is 12x1.5.
    And are you talking about the washer on the lug being loose?
  7. Oct 22, 2011 at 3:55 PM
    Chainsmoker
    Ed
    Phila.PA
    I think he is referring to the chrome sleeve over the lug nut.
  8. Oct 22, 2011 at 3:59 PM
    KPT
    09 Prerunner
    Ah, i did not realize they actually have a sleeve on them. I assumed they were just chrome plated on the base metal.
  9. Oct 22, 2011 at 4:12 PM
    CQB 1911
    Jesse
    AZ.
    2010 TRD OR AC
    I know right... Chrome sleeves - really!!! Sometimes Toyota really makes me wounder what the fuck there thinking. :mad:
  10. Oct 22, 2011 at 4:13 PM
    Chainsmoker
    Ed
    Phila.PA
    Yea the have a crimped sleeve around them. they really suck. when they come loos they gut stuck inside your wrench and if you attempt to use the same size socket you strip them.
  11. Oct 22, 2011 at 4:14 PM
    KPT
    09 Prerunner
    Wow, I have aftermarket lugs so I never knew. That sucks.
