OEM oil filter cover
Discussion in '3rd Gen. Tacomas (2016-2023)' started by maileboy, Jun 30, 2018.
  1. Jun 30, 2018 at 7:30 PM
    maileboy
    maileboy [OP] Well-Known Member
    David
    Mt. View (Big Island) but from Maili
    2017 TRD OFF-ROAD 4dr 3.5-auto, Magnetic Grey
    OK, so I finally put on the aluminum oil filter cover found on TW threads, TOYOTA OEM #15620-31060 from Amazon and it went on smooth, everything same as plastic cover, new filter, O ring in right groove, cleaned engine side threads, oiled everything and put it on, cover was torqued to spec and it butt up against the block. Wiped any oil around area. Drove for 50 miles and found it weeping where it meets block. Checked oil, no loss.
    Looked up part on Toyota parts and it's for an Avalon! Local dealer only has # for plastic cover, anybody else have this problem? Really like it, plastic cover looks like it would give probs later on and it was a bear getting it off, tight all the way!
    And yes I searched and found nothing about this problem. Any info would be appreciated.
  2. Jun 30, 2018 at 7:32 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The part # will not show Tacoma because we only get the plastic version from the Factory, I am sure you are just seeing a little residual oil and will be fine.
    Vbpiper likes this.
  3. Jun 30, 2018 at 7:37 PM
    maileboy
    David
    Ok shakerhood, I'll keep an eye on it and update if it keeps leaking. Thanks for the reply, have good 4th!
    Vbpiper and shakerhood like this.
  4. Jun 30, 2018 at 7:38 PM
    shakerhood
    Southern Ohio
    NP Bro, enjoy the 4th too!
  5. Jun 30, 2018 at 7:40 PM
    maileboy
    David
    Will do, thanks.
  6. Jun 30, 2018 at 7:57 PM
    maileboy
    David
    Vbpiper, the only guy that used to crush cars got busted by EPA for contamination in ground, so nobody's takeing cars for recycling......and Toyota's are gold over here, it's crazy...towing company's are storeing cars all over the place! I know it's an eyesore!
    shakerhood and Vbpiper like this.
  7. Jul 1, 2018 at 5:47 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Got mine from Amazon too. Never an issue.
    What Shakerhood said.
    G.
  8. Jul 1, 2018 at 5:58 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    I put the same cover on my Wife's 4Runner. Like Shakerhood said you are probably just seeing residue from the change. I too did not feel good about the plastic one that is why I changed mine.
    shakerhood[QUOTED] likes this.
  9. Jul 1, 2018 at 6:28 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Well I changed mind out to this aluminum one and had a small leak too, so I went back to the original plastic one. No doubt it was a leak by the block and the o ring was installed correctly and filter was more than tight.
  10. Jul 1, 2018 at 6:33 AM
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    Get the Baxter Performance adapter and use a normal spin on filter. High quality part although a bit pricey at $195. I use the WIX 51348 which has more filter area and has a drain-back feature which you don't get with the canister. Oil changes are a breeze and you never have to remove it again.
  11. Jul 3, 2018 at 5:04 PM
    Mod fan
    Mod fan Well-Known Member
    Definitely interested in doing this, changed the oil for first time last night , is there any clearance issue with the stock skid plate ? Also how do you know which wix filter to use ?
  12. Jul 3, 2018 at 6:18 PM
    shift96
    shift96 Well-Known Member
    If the plastic one is so bad why does the upgraded one leak?
    rtzx9r likes this.
  13. Jul 3, 2018 at 6:19 PM
    Mod fan
    The Baxter one doesn’t leak , it’s the other shitty designed Toyota one
  14. Jul 3, 2018 at 7:14 PM
    TomTwo
    Bill
    I-85 Southbound
    I ordered my Baxter Performance adapter today $ 199.99. for my Wife's 2017 4Runner. :thumbsup:
  15. Jul 4, 2018 at 4:27 AM
    Xena1
    Ron
    Plenty of room with stock skid plate. Filter size/thread is called out from Baxter. Just happens to be the filter used in 2nd generation Tacomas. I use WIX but you can get any other brand to fit, goes on easy and you can get both hands on filter to loosen/tighten.
    TomTwo and Mod fan[QUOTED] like this.
  16. Jul 4, 2018 at 5:55 AM
    Mod fan
    Definitely getting it for next change. No brainer , that design is terrible, thanks for info
  17. Jul 4, 2018 at 6:40 AM
    Xena1
    Ron
    Pretty easy to install. You will need a 1" deep socket and a 12MM allen. You have to remove the silver retaining clip on the side of the OEM canister and you can just pull it out with a pliers. Lube the o-rings on the adapter, thread in, and tighten to 25 ft lbs. Then thread in the nipple (I used a few dabs of blue loctite) tighten it down with the allen wrench and then install filter. Because the filter is vertical to the motor, you can fill it with oil before screwing it on. Instructions did not call for loctite, and I contacted Baxter about that. They said it was optional, but I wanted to make sure the nipple would not thread out when I loosened the filter.
    TomTwo likes this.
  18. Jul 4, 2018 at 6:05 PM
    bill8331
    bill8331 W9LSC
    bill
    central IN
    17 SR5 V6 4x4
    SCS F5, 5100, Kenwood-Kicker/Polk
    Great, another "thing" i didnt know about that i have to have.:spending:With this adapter and a Fumoto EZ-Drain, oil changes will be easy and clean. thanks for the info.
  19. Jul 23, 2018 at 6:23 AM
    IkemanTx
    IkemanTx Well-Known Member
    Isaac
    2017 4X4 SR5 Tacoma
    Any idea which fumoto fits the 3rd gen? I see several models.
  20. Jul 30, 2018 at 8:24 AM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Question for the ones that have the Baxter adapter.
    Since the adapter with the oil filter can have a larger capacity of oil compared to the OEM cartridge filter, is there a loss or reduce oil pressure in the engine? Is the OEM oil cartridge volume calculated to the engine oil pump?
    As example, you have an air vacuum pump (house dust vacuum) with 2 houses, one standard 2" and another one 4" diameter. The smaller one will have more suction power compared the the larger one.
