OEM oil filter part number
Discussion in '4 Cylinder' started by tenringtaylor, Oct 28, 2013.
  1. Oct 28, 2013 at 5:42 PM
    tenringtaylor
    tenringtaylor [OP] Member
    Hey guys I have a 2014 AC 2.7l and I'm going to get some OEM oil filters on ebay. Can anyone tell me the oem part number. Is it the YZZG1 filter?
  2. Oct 28, 2013 at 7:17 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    Welcome to the forum. The correct oil filter for the 2.7 litre , 4 cylinder model is 90915-YZZG1 or 90915-YZZD1 according to my 12 manual. It should be the same for your new 14.
    You were told that the dealership will do your oil changes for the next two years for free. You can change your oil early if you want to, as the owner, but their is no need to change it early. It is a quality synthetic oil and is good for 5000 miles by the factory oil change standards. But it is your Taco and you can do what you want to do. Good Luck.
  3. Oct 28, 2013 at 7:22 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Yes. That's the one I'm looking at.
  4. Oct 29, 2013 at 5:04 AM
    tenringtaylor
    thanks guys. I know I don't have to change the oil early but I'm a little overly protective at this point.
  5. Oct 29, 2013 at 1:00 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Change the rear end lube around 7k; you wont believe the shit that comes out. Grease the driveshaft u-joints, too!
  6. Oct 29, 2013 at 5:52 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    The filter for the v6 will fit with no problems, also. I figure it is a little longer, hence more filtering area. I do not recall the part number, tho it has been discussed on several threads here.
