OEM Oil Filter??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacobale, Nov 25, 2009.
  1. Nov 25, 2009 at 10:52 AM
    tacobale
    tacobale [OP] Well-Known Member
    Just changed my oil for the first time and I cut open the OEM filter to check it out. Has anyone did this?
    What kind of media is inside? Looks real crumbley. Like it could crumble and get inside the engine. It's some kind of suspended, hard but porous media of some kind held together with a plastic housing.
    That didn't look very good to me. I use WIX for all my vehicles. The WIX was about 1/2" shorter but that's OK.
    Does anyone know anything about this? This filter looks like something Toyota uses for start-up purposes?? The Toyota filter in Chris4x4's tutorial looks the same on the outside but is clearly different at the gasket area and the media inside the hole. Looks like a paper filter.
  2. Nov 25, 2009 at 11:24 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    How about a pic and the part number ?
  3. Nov 25, 2009 at 1:32 PM
    Jeff
    Jeff Well-Known Member
    Hopkinton,MA
    Nice 6spd,V6, very solid truck
    None currently, but I would like a better sounding exhaust and perhaps a cold air pack and some color coded step bars
    You know, if you are into all that perhaps on your next change out, do it at 3K pull the filter, cut it open and send the pic's , then on to 5K, 7,500K. Might be nice to see the difference with the added mileage.... just an idea.
    Jeff, SR5, V6, 6spd
  4. Nov 25, 2009 at 1:48 PM
    tacobale
    I'll get some pics up ASAP. If I can figure out how to do it....
  5. Nov 25, 2009 at 1:55 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    All I know is the last two filters I got at the dealer were different sizes... shifty
  6. Nov 25, 2009 at 2:01 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    I think the filter you're referring to are these:
    http://www.l-tunedparts.com/product/?id=2217
    Scroll all the way down and you'll see them. These are the oil filters made in Japan, one of the best filters that money can buy.
  7. Nov 25, 2009 at 2:13 PM
    tacobale
    OK got a pic, if you click on the camera in my first post, the pic is in my album. Part number is 90915-20004
  8. Nov 25, 2009 at 2:29 PM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    Wow, good stuff.
    I wonder why Toyota USA isn't buying these any more...moved to something cheaper?
  9. Nov 25, 2009 at 2:52 PM
    Asgard
    That is the only filter I use for my truck, pricey but it is superior to the one imported from Thailand IMO.
  10. Nov 25, 2009 at 3:42 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    The bottom line (i.e. to save money) is why they did it.
  11. Nov 25, 2009 at 3:50 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Hmmmm interesting. I ordered some Toyota OEM oil filters for my truck a few months back.:rolleyes: So you guys are saying there are different kind of OEM filters for our trucks that Toyota makes?:confused:
  12. Nov 25, 2009 at 3:58 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Yes, they will be different. These are imported directly from Japan while the ones you get at the dealer are usually made in Malaysia or Thailand.
  13. Nov 25, 2009 at 4:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I dont mind useing the ones from the dealer. My oil samples come back really good.
  14. Nov 25, 2009 at 4:23 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    ^ I agree with Chris. If you change your oil and filter on a regular basis it really doesn't matter what oil and/or filter you use.
  15. Nov 25, 2009 at 8:39 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Okay cool, got yah!!;)
  16. Nov 25, 2009 at 8:50 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I don't entirely agree with that but since I hate "my oil is better than yours!" threads I'll leave it alone. But generally, yeah, if you change your oil regularly you will have less, if any, problems.
  17. Nov 25, 2009 at 8:52 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Hey chris did you say you changed yours every 3000 or 5000?
  18. Nov 26, 2009 at 4:40 AM
    Jeff
    Hopkinton,MA
    I do agree that changing the oil and filter often is the key to engine life. There are some filters that are just better than others.
    One of the sites list the filter elements after disecting many filters and you do need a filter with a by pass.....you just cannot go wrong with a quality filter, no matter who's it is. Any good oil will do the trick . Syn or dino.....I just prefer syn for its cold and heat property's.
    Jeff, 06, V6, SR5, 6spd
  19. Nov 26, 2009 at 9:16 AM
    tacobale
    So I guess the conclusion to the filter issue is that it is a very good filter as opposed to a bad filter. Then that is the kind of filter you want on a new engine. There were no metal that I could see on the media.
