OEM Oil filter
Discussion in 'Technical Chat' started by tacoma guy, Sep 9, 2023.
  1. Sep 9, 2023 at 9:12 AM
    tacoma guy
    tacoma guy [OP] Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Hey guys , have a question. I have a 2gen Tacoma with the 4.0 V 6. I am running the OEM Oil filter purchased from the dealer. I was changing my oil this morning and when I went to remove the filter on oil grained out . The truck sat over night . I have never had this happen before . Oil alwaysed grained out . So my question is what does this mean and is that harmful to the engine?
  2. Sep 9, 2023 at 9:21 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I’ll bite. What is “grained out”?
    Bivouac likes this.
  3. Sep 9, 2023 at 9:24 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Drained.
  4. Sep 9, 2023 at 9:26 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I think he meant oil drained out of the oil filter, which would be normal. If it didn't before, the anti drain valve was not doing its job right.
  5. Sep 9, 2023 at 9:27 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    If by grained you mean drained, and by on you mean no, I would guess that the anti drainback valve on your old filter went bad and stopped keeping oil up in the engine above it.
  6. Sep 9, 2023 at 9:28 AM
    BLtheP
    Plano, TX
    I think he meant this time it DIDN'T drain out (on meant no) and that it always drained out before. Probably a drain valve problem this time around.
  7. Sep 9, 2023 at 9:28 AM
    tacoma guy
    Joe
    Phoenix Az.
    I ment drained !
  8. Sep 9, 2023 at 9:35 AM
    tacoma guy
    Joe
    Phoenix Az.
    That is exactly what I meant. Thank you for understanding what I meant ! I was in a hurry and didn't check my spelling guys . Thanks for the replys ! So no harm was done by the drain valve not doing its job and the oil was still being filtered?
  9. Sep 9, 2023 at 9:36 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Yes
  10. Sep 9, 2023 at 9:37 AM
    BLtheP
    Plano, TX
    The anti drainback valve is part of the oil filter and keeps oil up in the engine when the engine is shut off, so that when you go to start it next time, oil is right there for the parts. Bad valve means oil drains back into the pan, and when you go to start, if the oil all drained back, the parts would be moving without oil for a second or two. It could eventually be a problem, but if you didn't hear any noises or anything then I wouldn't be too concerned.
    When you change the filter, the engine loses all of it's oil anyways so every time you do an oil change you create the same situation. Not that that's good, but just a fact of how things work. If you didn't hear any weird oil related noises I would not be worried.
    Oil was still being filter, yes.
  11. Sep 9, 2023 at 9:50 AM
    tacoma guy
    Joe
    Phoenix Az.
    First let me say THANK YOU for that info and explaining that ! No I didn't hear any weird noises so I am going to chalk it up as it will be fine . Much appreciated my good sir !
  12. Sep 9, 2023 at 9:53 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Bivouac likes this.
