OEM oil filters vs aftermarket?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Illini Tacoma, Jan 17, 2022.
  1. Jan 17, 2022 at 9:02 AM
    Illini Tacoma
    Illini Tacoma [OP] Well-Known Member
    2016 Dark Red Double Cab Short Box
    I've got the facilities and what I believe is the common sense acumen to do my own oil changes. Wanted to see what the general consensus on a couple of questions from you long time Taco people:
    Is genuine Toyota oil filters preferable and advantageous to lets say a filter available at NAPA or one of the other parts supply stores?
    Is full synthetic oil preferable to a synthetic blend or even a conventional?
    I know thoughts and beliefs concerning change intervals vary from one owner to another but I've settled on 7500 mile oil change guidelines. Is that interval about right?
    davidstacoma and tacotoe like this.
  2. Jan 17, 2022 at 9:04 AM
    ClimbMaintain
    ClimbMaintain Well-Known Member
    2020 Tacoma TRD OR DCSB AT
    Full synthetic and OEM filters. Done and done.
    BRFab, bbartol, DanoTay and 13 others like this.
  3. Jan 17, 2022 at 9:05 AM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    I myself choose to use toyota filters, have I ever had an issue with napa filters? No. Full synthetic is definitely the best option to protect your engine. As far as the interval toyota I believe says 10,000. The most common is 5,000 so you are right about in the middle. I prefer to do my own soon rather than later becasue it is relatively cheap insurance
    Illini Tacoma[OP] and tacotoe like this.
  4. Jan 17, 2022 at 9:07 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I did my first oil change at 500 miles then 3500 and then the dealership did the 10k and 20k for u der the freeoil changes. I also got oil changes and state inspections for life. I used OEM.
    tacotoe likes this.
  5. Jan 17, 2022 at 9:07 AM
    Delta09
    Delta09 OSHA Violator
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Your truck takes 0w20, that's all full synthetic. Filters, stick with OEM.
  6. Jan 17, 2022 at 9:11 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    OP, check your Owner's Manual for specifics on oil viscosity, recommended API grade and change interval. Follow that and you won't have any issues.
    Oil filter wise, some of the best are Toyota, WIX, Napa Gold, Bosch, ACDelco. Use a quality filter at every oil change. Any of those are quality filters.
    Synthetic, Blend or Dino are all good as long as they meet the API grade and Viscosity.
    Many opinions, many internet based stories, partial rational........and a big heavy dose of BS. Of course, there will be those who will claim what they use is the best and anything else will result in dire results.
    Barsoom and Illini Tacoma[OP] like this.
  7. Jan 17, 2022 at 9:12 AM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    I use the cheapest 0w-20 synthetic and OEM filters...
    Lately it's been a 6qt box of Havoline from walmart.com for $20.
    OEMpartsource.com sells the OEM filters for $3.50. I order some when I need wipers, etc. Doesn't get much cheaper than that...
  8. Jan 17, 2022 at 9:17 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    OEM & Fram Ultra filters are available at your local Walmart at around the same price. I've used both & cut them open. They're good stuff. Mobil 1, Castrol 0w-20 is what I use.
  9. Jan 17, 2022 at 9:20 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  10. Jan 17, 2022 at 9:21 AM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
  11. Jan 17, 2022 at 9:22 AM
    Robnik
    Rob
    Greenacres, Florida
    FTW! ;)
    Kwikvette and tacotoe like this.
  12. Jan 17, 2022 at 9:23 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Napa Gold are USA made Wix.
  13. Jan 17, 2022 at 9:23 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Toyota filters can be found for cheap online, or on the shelf at Walmart.
    0W-20 only comes in synthetic.
    10,000mi. No question and no worries.
    Get a good cartridge filter wrench that grabs the flutes:
    https://www.amazon.com/gp/product/B073XF45NF
    geo8866 and tacotoe like this.
  14. Jan 17, 2022 at 9:23 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Wrong one for the 3rd Gen . . .
  15. Jan 17, 2022 at 9:24 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Not for the V6 3rd Gen
    Junkhead, shakerhood, geo8866 and 2 others like this.
  16. Jan 17, 2022 at 9:26 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    RustyGreen, geo8866 and tacotoe like this.
  17. Jan 17, 2022 at 9:27 AM
    Robnik
    Rob
    Greenacres, Florida
    Then you're screwed, lol. They switched to cartridge? They suck.
  18. Jan 17, 2022 at 9:33 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No they don't.
  19. Jan 17, 2022 at 9:34 AM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    I only use Chuck Norris aftermarket brand filters, they’re rated at 100,000 mile servicing intervals. They can be used as makeshift Molotov cocktails once used up so there’s no waste or need to recycle.
  20. Jan 17, 2022 at 9:37 AM
    Robnik
    Rob
    Greenacres, Florida
    Yes they do. Try getting it off with your hand. What a mess.
    tacotoe likes this.
