OEM or aftermarket swaybar end links?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dryheat, Mar 5, 2025.
  1. Mar 5, 2025 at 9:40 AM
    dryheat
    dryheat [OP] Well-Known Member
    Should I just go with OEM? I'm going to do the bushings while I'm at it. 2019 TRD OR, 28mm bushings, right?
    Anyone got torque specs for the end links?
  2. Mar 5, 2025 at 9:41 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    What's a sway bar? :)
  3. Mar 5, 2025 at 9:43 AM
    dryheat
    It's for us tool bags that need to take the freeway to work
  4. Mar 5, 2025 at 10:08 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    I live in Phoenix. You take the freeway everywhere here. If your suspension is beefed up, try without it. Rides so much softer and the body roll is fun.
    Else, whatever endlinks should be fine. I've had decent luck with Moog in the past, but their quality seems to fluxuate.
  5. Mar 5, 2025 at 10:20 AM
    dryheat
    I'm in Phoenix as well. I'll think about it. I didn't want to run into other problems like UCA hitting coilovers etc
  6. Mar 5, 2025 at 10:27 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Good deal. It takes about 15 minutes to remove. A quick test to see how you like it. Removing it will not make the UCA hit anything if it doesn't already. The biggest issue is generally the sway bar/links hitting the coils. Removing it just lets the front end operate fully independently. Huge ride quality increase but overall still feels pretty stable unless you barrel into the inside lane on the i10 eastbound under the stack near the airport doing 85. Then it's a little sketch lol.
  7. Mar 5, 2025 at 10:35 AM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
  8. Mar 5, 2025 at 10:47 AM
    eurowner
    eurowner Duke Sky
    Scoty
    dryheat[OP] likes this.
  9. Mar 5, 2025 at 10:49 AM
    MGMDesertTaco
    The way I drive I'm leaving mine on. :rofl::burnrubber:
  10. Mar 5, 2025 at 10:56 AM
    eurowner
    eurowner Duke Sky
    Scoty
    :fistbump: totally!
    MGMDesertTaco[QUOTED] likes this.
  11. Mar 5, 2025 at 11:14 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Wimps lol
    eurowner[QUOTED] likes this.
  12. Mar 5, 2025 at 11:20 AM
    dryheat
    Guess I'll just go OEM :)
    Those are going in the bookmark folder "Eventually maybe".
    So, anyone got torque specs handy or should I just go with "tight as shit"
  13. Mar 5, 2025 at 11:50 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I have a brand new set of MOOG end links, I'm not going to use.
    I left the swaybar off to see how it drove and never put it back on.
    Make an offer and you can have them.
  14. Mar 5, 2025 at 11:57 AM
    dryheat
    Honestly I'm probably just going to go OEM. You can get them for $110 a piece right now which isn't bad. Thanks though.
    bkhlrTaco's[QUOTED] likes this.
